Home > Maintenance & Modifications > Sill rail replacement
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
I have searched to see if I can find an answer, alas I cannot.
My sill rails are shot. Flaking and badly rusted.
My intention is to replace them with YRM galv rails.
I take it that on a 90, it is a case of simply unbolting the old ones and bolting the new ones in place? No welding or cutting required.
Post #829102 3rd May 2020 9:08pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Morning
i have just taken mine off and replaced with rock sliders (much stronger, looks better and better side impact protection).
On the 90 there are approx 5 bolts to undo on each side and over half of mine were so corroded they snapped off Shocked
Worst ones were at the front end connecting bracket to chassis. Also...watch out for eyefuls of mud/dust
Consider a better alternative to the LR sills as they are flimsy.
Tommo
Post #829139 4th May 2020 7:07am
No welding required.
Cutting on the other hand...... you may find all your bolts rusted to the nuts, best to hope for them to snap!
It’s worth making sure you have plenty of new hardware in case. Have a good look around all your fixing points before tackling the job and hit them with wd40 a few days in advance and then daily. QRZ 2e0vpf
Post #829140 4th May 2020 7:11am
Hopefully you mean these, not side steps, as Tommo may be thinking of.
 QRZ 2e0vpf
Post #829144 4th May 2020 7:15am
Jeebs
Yep Greeni there the ones!
Post #829158 4th May 2020 10:04am
Tommo
Embarassed Anyway to get to them you still need the sills off Very Happy
Post #829227 4th May 2020 4:48pm
