Home > Technical > Alarm and indicators when locking/unlocking |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 331 |
I don't have access to a Nanacon, but I do have a multimeter. I'll have another bash at it tomorrow. Thanks guys!
23rd Apr 2020 5:29pm |
Alarm Remote with low battery (as wrote on the User manual) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
24th Apr 2020 12:52pm |
I have already tried a new battery in the remote.
24th Apr 2020 2:26pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
Check to see if you have the overlay kit fitted. macfrank gave me some info on it. This was what caused mine to display the same issues as yours. Overlay kit was installed badly and had corroded at the joins.
https://www.defender2.net/forum/topic35353.html |
24th Apr 2020 3:27pm |
Not a lot of time to investigate further today as I had to appease SWMBO and do some gardening!
However, I did notice something else when I finally got a chance to look at the Defender: with the ignition on there is a steady ticking noise at the nearside front - sounds like it could be from behind the headlight. It could be related. |
25th Apr 2020 6:28pm |
I've tested fuses and connections.
Without access to a Nanocom or other fault code reader, I can only think that the AS10 is faulty or needs reprogramming. Is it possible the AS10 lost its settings whilst the dash was out? |
2nd May 2020 6:03pm |
