Home > Maintenance & Modifications > Which type of grease
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I have tried a search but unfortunately it brings up so many results its hard to go through them all, so;
Could you folks recommend which types of grease for the following
Prop shafts
Wheel bearings etc
Anti seize
Others (Please specify what it is used on)
And of topic a little - which loctite?
Thanks in advance.
Mick
Post #828608 30th Apr 2020 6:31am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Prop shafts Lithium
Wheel bearings etc Lithium
Anti seize Aluminium grease or i use Shimano bike antiseize
Others (Please specify what it is used on) red rubber grease for brakes calipers
And of topic a little - which loctite? blue for medium strength, i prefer the green stronger stuff
Thanks in advance.
Mick
Post #828609 30th Apr 2020 7:01am
bear100
I use Coma products where applicable
Prop shafts Lithium general purpose Coma
Wheel bearings etc High performance bearing grease Coma
Anti seize Aluminium grease Copper ease Coma
Others (Please specify what it is used on) ACF 50 a multiple of use's
And of topic a little - which loctite? i have always used Rocol lock tight, never let me down......so far any way! 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #828620 30th Apr 2020 8:44am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
And if you really, really, really wanted to be maniacal you'd use moly grease (that 'orrible black stuff that gets everywhere) on the prop shaft sliding joint. I've only got some in the garage 'cos I use it on classic king-pins, otherwise lithium is just as good.
Peter
Post #828645 30th Apr 2020 11:33am
Mossberg
I have noticed Granville do a multi purpose grease (shows a picture of a wheel bearing on it) and a CV grease that has the Molybdenum in it. What is the difference and can one be used for both or is it better to use them on the different items.
I only really want to have one grease gun as it is for my truck only so I don't expect to be using silly amounts of it.
Thanks for all the help so far. I have wanted to give the truck a full service including oils but I have picked some work up and that is keeping me busy, but I want to be prepared for when I can start it!
Mick
Post #828693 30th Apr 2020 4:55pm
Bluest
Grease with molybdenum is better for sliding surfaces, like you get on splined shafts or inside CV joints. Plain Lithium grease is intended for rolling surfaces like wheel bearings etc. There are mixed views on whether you should use moly grease in roller bearing applications, or weather it encourages the rollers or balls to skid. 2007 110 TDCi Station Wagon XS
Post #828695 30th Apr 2020 5:03pm
Mossberg
Ah, ok. Standard lithium grease then for the gun. If it comes to doing the CV joints I will look at that then. Or I may have one of the small push grease guns in the garage that I could use for the prop.
Thanks for the help.
M
Post #828696 30th Apr 2020 5:09pm
Bluest
Normal Lithium grease is fine for all of the prop shaft's needs. Defenders use a special Thixotropic "one-shot" grease anyway for the CVs 2007 110 TDCi Station Wagon XS
Post #828698 30th Apr 2020 5:16pm
Hufflepuff
Both Gwyn Lewis and Ashcroft are recommending "Morris K48" grease for general purpose use, CVs and Propshafts:
https://gwynlewis4x4.co.uk/product/morris-...artridges/
which is a Lithium based grease. I have used it fairly liberally, its thick sticky stuff which tends to go everywhere, but I guess that's a good thing unless you do your own washing... 2005 Td5 90 XS
1989 V8 110 CSW
Post #828718 30th Apr 2020 8:22pm
ericvv
Post #828784 1st May 2020 4:03pm
miker
Lithium with Molybdenum, which is what most people would know as CV grease.
However I do trust ashcroft to know their stuff! Personally I've always used "normal" lithium grease for wheel bearings, props, and other "high speed" stuff, and moly grease for CV's and "lower speed" stuff.
In reality, for most applications, fresh grease and the right amount of it is way more important than the exact spec!
Post #828791 1st May 2020 5:42pm
Mossberg
ericvv wrote:
For anti seize, nothing better than this one here. Metals free and will never harden and break to pieces as some other do.
Eric
Is that similar to this ceramic paste? Weicon is almost 3 times the price of this.
https://www.ebay.co.uk/itm/392596518324
Post #828983 3rd May 2020 4:41am
Mossberg
Eric
Post #828998 3rd May 2020 9:10am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Do you reckon I could use this in the UJs and wheel bearings?
Rocol Lithium Grease 380 g Sapphire® Advance 2
https://www.rocol.com/products/sapphire-ad...ing-grease
I've got a cartridge in my tool box, that I 'acquired' at some point, but have never really used. Seems a waste to buy something else, if this would do the trick. 2011 CSW XS 90
Post #937716 14th Jan 2022 4:24pm
Co1
^^^ It’ll be reet!!
Post #937718 14th Jan 2022 4:36pm
