|  | Home > Maintenance & Modifications > Which type of grease |
| windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311      | Prop shafts  Lithium
 Wheel bearings etc Lithium Anti seize Aluminium grease or i use Shimano bike antiseize Others (Please specify what it is used on) red rubber grease for brakes calipers And of topic a little - which loctite? blue for medium strength, i prefer the green stronger stuff Thanks in advance. Mick | ||
|  30th Apr 2020 6:01am |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027      | I use Coma products where applicable
 Prop shafts Lithium general purpose Coma Wheel bearings etc High performance bearing grease Coma Anti seize Aluminium grease Copper ease Coma Others (Please specify what it is used on) ACF 50 a multiple of use's And of topic a little - which loctite? i have always used Rocol lock tight, never let me down......so far any way! 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) | ||
|  30th Apr 2020 7:44am |
| Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 889      | And if you really, really, really wanted to be maniacal you'd use moly grease (that 'orrible black stuff that gets everywhere) on the prop shaft sliding joint. I've only got some in the garage 'cos I use it on classic king-pins, otherwise lithium is just as good.
 Peter | ||
|  30th Apr 2020 10:33am |
| Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553      | I have noticed Granville do a multi purpose grease (shows a picture of a wheel bearing on it) and a CV grease that has the Molybdenum in it. What is the difference and can one be used for both or is it better to use them on the different items.
 I only really want to have one grease gun as it is for my truck only so I don't expect to be using silly amounts of it. Thanks for all the help so far. I have wanted to give the truck a full service including oils but I have picked some work up and that is keeping me busy, but I want to be prepared for when I can start it! Mick | ||
|  30th Apr 2020 3:55pm |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341      | Grease with molybdenum is better for sliding surfaces, like you get on splined shafts or inside CV joints. Plain Lithium grease is intended for rolling surfaces like wheel bearings etc. There are mixed views on whether you should use moly grease in roller bearing applications, or weather it encourages the rollers or balls to skid. 2007 110 TDCi Station Wagon XS | ||
|  30th Apr 2020 4:03pm |
| Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553      | Ah, ok. Standard lithium grease then for the gun. If it comes to doing the CV joints I will look at that then. Or I may have one of the small push grease guns in the garage that I could use for the prop.
 Thanks for the help. M | ||
|  30th Apr 2020 4:09pm |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341      | Normal Lithium grease is fine for all of the prop shaft's needs. Defenders use a special Thixotropic "one-shot" grease anyway for the CVs 2007 110 TDCi Station Wagon XS | ||
|  30th Apr 2020 4:16pm |
| Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727      | Both Gwyn Lewis and Ashcroft are recommending "Morris K48" grease for general purpose use, CVs and Propshafts:
 https://gwynlewis4x4.co.uk/product/morris-...artridges/ which is a Lithium based grease. I have used it fairly liberally, its thick sticky stuff which tends to go everywhere, but I guess that's a good thing unless you do your own washing... 2005 Td5 90 XS 1989 V8 110 CSW | ||
|  30th Apr 2020 7:22pm |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817      | For anti seize, nothing better than this one here. Metals free and will never harden and break to pieces as some other do.
 Eric   Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw | ||
|  1st May 2020 3:03pm |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791      |
 Lithium with Molybdenum, which is what most people would know as CV grease. However I do trust ashcroft to know their stuff! Personally I've always used "normal" lithium grease for wheel bearings, props, and other "high speed" stuff, and moly grease for CV's and "lower speed" stuff. In reality, for most applications, fresh grease and the right amount of it is way more important than the exact spec! | ||
|  1st May 2020 4:42pm |
 Is that similar to this ceramic paste? Weicon is almost 3 times the price of this. https://www.ebay.co.uk/itm/392596518324 | ||
|  3rd May 2020 3:41am |
|  3rd May 2020 8:10am |
| SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296      | Do you reckon I could use this in the UJs and wheel bearings?
 Rocol Lithium Grease 380 g Sapphire® Advance 2 https://www.rocol.com/products/sapphire-ad...ing-grease I've got a cartridge in my tool box, that I 'acquired' at some point, but have never really used. Seems a waste to buy something else, if this would do the trick. 2011 CSW XS 90 | ||
|  14th Jan 2022 3:24pm |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3788      | ^^^ It’ll be reet!! | ||
|  14th Jan 2022 3:36pm |
| Posting Rules
