![]() | Home > Td5 > Retrofit puma doors on base spec td5 |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Any 10AS will work.
You just need the relay from NEC it's a EP2 3N1S It's prolly about 2 bucks. THen you just need to program it to get it talking to the ECU and then enable the CDL and alram if needed. I cheated and drilled a hole in my 10AS cover to get the CDL wires out to connect to my own loom to drive the CDL. The defender has migrated, leaving the owner behind. |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Would it be possible to install a 10AS unit in a non-ECU vehicle and use only its central locking function? I realize that numerous aftermarket products are available which do just this, but I'm rather crazy about using genuine parts where I can and getting details like the correct key fobs.
Once again, thanks in advance! |
victor normandy Member Since: 13 Jan 2019 Location: Ivory Coast Posts: 3 ![]() ![]() |
I know that thread is really old but Gilarion you say that electric front windows do not use a relay, but it says the contrary on the wiring diagram i have,
I'm asking this because i'm currently doing the same thing now, retrofitting power windows and CDL on a 99MY TD5
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6715 ![]() ![]() ![]() |
What is meant is that the switches are not used to trigger relays for the motor power, the switches directly connect to the motors.
There is an ignition triggered relay on the 2002MY and later Defenders - this supplies the window switches. So the relay is “upstream” of the switches (supplying them) not “downstream” (controlled by them) ![]() ![]() |
Oh ok thanks
GregOb' Member Since: 17 Nov 2021 Location: France Posts: 5 ![]() ![]() ![]() |
Hi All,
I'm also about to do this upgrade in my TD4 2.4L MY2012 (Durisotti version). I sadly don't have the connectors/looms already installed in this version so I will have to do everything myself. Before putting the hand on the 10AS unit, does someone have an idea if this version has the relay or not? I have bought all the genuine parts to complete the retrofit but I'm missing the connectors of all actuators @PaulMc, so I'm interested about buying these from you if you still have a few in stock. Could you pm/email me? I will be more than happy to post few pictures of the progress if that can be of any help for the next ones ![]() |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 ![]() |
Hello. How to connect the AMR2496 Switch? In Chinese windows. Thank you http://www.clublandrovertt.org/index.php?a...ype=avatar
