Home > In Car Electronics > Indicators both on
barrowg
United Kingdom 1990 Defender 90 200 Tdi HT Corris Grey
Indicators both on
Hi all,
Not sure if anyone can help me, as id like the 90 to be up and running after all this is over so I can drive it legally in the summer. Currently whenever I turn an indicator on the other side also starts indicating however slightly dipped. I have checked for the obvious cross wire etc. But can’t find anything that would indicate a reason. They were all working perfectly before I left the car for a couple months during the winter. Nothing seems to have changed, but if anyone has any idea do let me know. Only thing I can think of is that I’ve updated the side indicators to LEDs, but I wouldn’t see how that would be a problem.
TIA
Post #828112 28th Apr 2020 12:39am
V8GPC
Do you have a single indicator direction lamp on your warning panel rather than one for each direction?
If you do then the circuit relies on the filament in the indicator lamps to provide a ground.
LEDs (diodes) work in one direction so no longer provide the ground
The side repeaters (filaments) were probably still doing this, now you have LEDs all round there isn't a sufficient ground anymore.
There is a fix for this
https://boltonbits.co.uk/rdx-earth-fix-kit...ators.html
https://www.ebay.co.uk/itm/RDX-Earth-Fix-K...2280619868
You could put both your side repeaters back to filament lamps to prove this is the issue before spending the cash.
Post #828122 28th Apr 2020 7:03am
grafty99
I'd say the same. I had a similar issue with my 110, same fix but I made the earth path myself Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #828126 28th Apr 2020 7:54am
dorsetsmith
LR using lamp filament as earth path ( PPE) on tdi 200 and 300 indicate panel Exclamation
small mod using diodes and wire
https://www.lrworkshop.com/connectors/defender-1996-300tdi/C230
green- white c230-9 -------- c230 -10 green -red
Post #828149 28th Apr 2020 9:30am
Martin
Site Admin
As a quick check, disconnect the warning light panel to remove the indicator warning light bulb from the circuits Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828187 28th Apr 2020 11:28am
barrowg
Perfect thank you all. Is there a quick fix, just to add a ground or connect to a ground to fix the issue? I’m not the best with wiring so will need a simple break down Laughing
Post #828210 28th Apr 2020 12:43pm
V8GPC
The easy fix is to buy the part, but not the cheapest. (pounds)
The alternative is the two diodes and small wire (pence) but you need a little electric know how
Post #828484 29th Apr 2020 2:04pm
barrowg
I don’t really want to spend £35 on earthing them, so is the diode way simple enough to do or will I need a bit more expertise?
Cheers all
Post #828493 29th Apr 2020 2:54pm
Martin
Site Admin
You would only need the one lamp kit, not two. It's a replacement warning panel light.
The fix that dorsetsmith gave above requires doing this:
Cut Green/White and Green/Red indicator supplies to the warning light connector (leaving enough wire on the connector to work with)
Connect the Green/Red tail from the white connector to a ground (nut on the back of the gauges is good)
Solder the anode of two diodes to each of the Green/White and Green/Red coming from the bulkhead loom. Join the cathodes together, then connect to the Green/White tail on the white connector.
This combines the two indicator warning light feeds for a single lamp without the issue of back-powering the opposite side.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828496 29th Apr 2020 3:01pm
Grouse
@BarrowG check your Flasher relay - I had exactly the same issue with both indicators being on and the relay was damp inside - visual condensation. I took it off, dried it out and sprayed with WD40 then re-sealed it.
This cured the issue and cost nothing 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #828498 29th Apr 2020 3:05pm
barrowg
Thanks very much Martin doesn’t seem too hard at all.
Post #828501 29th Apr 2020 3:42pm
barrowg
Cheers I will check this first. Where will I find the flasher relay? I do have a spare that came with my new wipacs when the others broke so could just swap them out
Post #828502 29th Apr 2020 3:43pm
barrowg
Hi all so I’ve just had a look and tried the different tests. I disconnect the white clip shown above and same problem happened so that could mean it isn’t the ground? I also read up else where that it could be the hazards causing a problem.
To follow up on what @Martin said about cutting wires and diodes I can’t seem to see a white/green or a green/red wire. Am I being stupid and looking in the wrong place?
Post #828509 29th Apr 2020 4:39pm
barrowg
The indicator warning light has also now stopped working before taking off the white clip?
Post #828511 29th Apr 2020 4:44pm
Martin
Site Admin
You’ll find them on the other flat white plug.
Green/White and Green/Red Smile
Did you try the flasher relay?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828513 29th Apr 2020 4:57pm
