Home > In Car Electronics > Drilling from battery box into rear passenger footwell
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I want to route some cable from the battery box into the rear passenger footwell so I can thread it behind the carpet and into the box under the driver's seat where I am planning to locate my auxiliary fusebox and also to do the security mod which stops a scrote from cutting the live cable that is routed under the vehicle.
There are two rubber stoppers in the battery box but they seem to come out under the car (even though eyeballing them it feels like they should come out in the passenger footwell). Anyway, since it is all internal, planning to get the drill to the box. Is there anything in the way I should be careful about (other then some alu or steel plate)?
If anyone else has done this, some pics would be appreciated.
Post #827867 26th Apr 2020 9:39pm
rallysteve
There is a void between the rear footwell and the battery box. You could drill right through and run the cable that way but it would seem a bit of a messy route with some tight bends needed in the cable.
Be aware that the main positive feed cable and the cables for the second row door switches and central locking run through that void.
Post #827870 26th Apr 2020 9:49pm
There is a gap between the back of the battery box and the second row footwell that is open to the elements from beneath.
Battery box on right, footwell on left:
: Darren
Post #827871 26th Apr 2020 9:52pm
kmac
Thanks chaps - so what's a good route staying inside the cab from battery box to drivers seat box?
Post #827872 26th Apr 2020 9:54pm
The usual route is across the back of the seats:
I bought a kit to do this, although I wouldn't particularly recommend it. There are more details here:
https://www.defender2.net/forum/post776416.html#776416 Darren
Post #827874 26th Apr 2020 9:59pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The fuse box under the drivers seat has two spare pre tapped holes, M5 or M6 , on the positive connection for the fuse box. If you lift the cover off the fuse box and look at the rear nearside corner you should see were the main feed comes in to the box, there is space to get at least two other cables in. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #827920 27th Apr 2020 9:16am
kmac
Cheers both will have a look. On the link posted by LanRoverAnorak there is an alternative suggested which is across the front of the first row of seats - will have a look at all options but I think because of the design of my dual battery set-up I will have to go round the back of the seats
Post #827949 27th Apr 2020 1:27pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Is this to get a power supply to the box under the drivers seat. No need, have a look at the thread from when I did it:
https://www.defender2.net/forum/topic70342.html
No need to drill any holes. There was plenty of additional slack in switched wired feed to just crimp a wire off that then went from the top of gearbox into the box under seat through the existing rubber grommet. It was a really easy job an did not require the loom extension. To protect the extension wire I used a length of 240 volt mains wire, stripped out the wires to leave just the rubber sheath as a conduit.
Post #827995 27th Apr 2020 5:01pm
It's more likely that the OP wants to do it in order to mitigate the extremely well-known security vulnerability in this area. That is the usual reason for this modification.
Post #828000 27th Apr 2020 5:25pm
kmac
^^^ this and my auxiliary fuse-box for fridge, work light etc will be in the driver seat box.
Voltage sensing relay for dual battery install will be in the under cubby safe.
I have the original VArta that came with my Puma and a Numax CXV30HMF Sealed Leisure Battery 12V 105Ah in the battery box so very limited space left there for the relay
Post #828018 27th Apr 2020 6:10pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
That was me Razz Very Happy
Here is where I posted the pics so you can see if it is likely to suit or not..... probably more likely not with your dual batteries though.
Thumbs Up
Post #828045 27th Apr 2020 8:06pm
kmac
Thanks Roger.
My planned set up - so far batteries are in and main one is connected so the truck runs.
Aux yet to be connectoed. Left box is battery box. Centre is under cubby safe (Mud) and right is driver seat box.
[/url]Dual Battery Sys by [url=https://www.flickr.com/photos/152440487@N03/][/img]
Post #828068 27th Apr 2020 9:23pm
boxoftricks
I ran mine around the front fo the seat box without the need to but any auxiliary kit/cable and the original cable was long enough.
Post #828136 28th Apr 2020 8:42am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
kmac wrote:
Thanks Roger.
Please place the 100A fuses close(r) to the battery. They're protecting the cables.
And while you're at it, you might want to add a fuse to the original cable for the same reason (it's *still* on my to do list... Sad )
Post #828261 28th Apr 2020 4:34pm
kmac
Yes, plan to move all fuses as close to battery clamps as possible.
Actually had a look at the Littelfuse battery clamp with three stud busbar incorporated. You can get tiny fuses that go over the stud but works out quite expensive. Link below.
https://m.littelfuse.com/~/media/commercia...holder.pdf
Post #828374 28th Apr 2020 10:19pm
