![]() | Home > Puma (Tdci) > Its happened again !!!! |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Bloody gearbox to transfer box shaft has stripped again. After last years debarkle with fitting the new shaft assy and all the leaks afterwards. Replacement gearbox beginning of the year and bang its happened again.
I have fitted the Ashcroft lubricated kit this time with new alignment dowles lets hope it all stays together this time. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
368 Thou
I thought it looked like it had slipped back the whole lot fell apart when I dropped the transfer box off. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17937 ![]() ![]() ![]() |
Hopefully the Ascroft kit will also limit the extent to which the parts could disengage in the event that the spring ring fails.
Impressive mileage, well done! |
