Home > Maintenance & Modifications > Removable CB aerial and Mud Seat Rails
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Yesterday me and my dad did the above, we were very pleased with the outcome. The aerial has a tested SWR reading of 1.2 so it should get perfect signal Smile The rubber pads stop the metal from damaging the paintwork Smile
It feels weird in the Defender now, the extra legroom provided by those rails is really nice Smile wdnt wanna be in the back seat though Razz
Jack
Post #82748 31st Jul 2011 12:53pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
don't be looking at my wiring then jack, mine looks like crap after seeing yours.
good job
by the way, watch out for the tax man, with an XS and seat covers then you add mud rails, you may end up too comfortable to qualify as a defender any more Laughing
Post #82816 1st Aug 2011 12:40pm
Landie Boy
haha thanks Smile
Jack
Post #82832 1st Aug 2011 2:43pm
landy andy
Just be very careful of that cb ariel mount if you go laning, it WILL come off and cause damage as it swings about.
Never known one of those types to last.
Sorry, but be careful
Andy
Post #82851 1st Aug 2011 7:58pm
^^^^ I agree... snapped mine off (prior to the end of the whip going right over and putting little dints in the opposite side of the roof panel)
Post #82852 1st Aug 2011 8:00pm
One slightly less vulnerable alternative would be to mount it on the back of the roof rather than the side. The cables would need re-routing through the back door, but that may leave less exposed anyway.
Another is to use a quick change fitting and swap for a rubber duck type aerial when using in areas with lots of trees. Darren
Post #82892 2nd Aug 2011 10:02am
df1
to be honest I don't see the need for the mud rails,
I just put a spacer under the back of the rails to raise up over the ledge abd fitted longer bolts, can now slide back over ledge.
Here's the front
Uploaded with ImageShack.us
And here's the back of the seat
Post #84232 13th Aug 2011 6:55pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Give that man a Cigar Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #84234 13th Aug 2011 7:06pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi df1,
Any idea what gauge and length of bolts you required, and the height of the spacer? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #84257 13th Aug 2011 8:27pm
BigMike
Andy
exactly.
Post #84258 13th Aug 2011 8:28pm
df1
As for the spacers, as far as I remember it was 2 m10 nuts and and 2 flat washers each side (about a euro worth).
Can't for the life of me remember the bolt size but I'll pull one out tomorrow and check.
Post #84262 13th Aug 2011 8:38pm
Landie Boy
Andy
exactly.
We did a wales trip including bala off road site and it didnt come off or do any damage Smile
Jack
Post #84272 13th Aug 2011 9:45pm
WelshGas
Thanks df1 Thumbs Up LANDYWATCH
Post #84274 13th Aug 2011 10:16pm
df1
Just had a closer look this morning, the bolts are M8 x 40 with a 10mm hex head, I've a feeling these are the original bolts - can't just remember but they look like it.
The washers are the heavy washers that are originally there but the M10 nuts I had to buy !!!!
The 2 washers and 2 nuts together add to 27mm, so basically you're raising the back of the seat 27mm and leaving the front the same.
I don't know if it makes any difference but my seats are Exmoor trim modular, same running gear as original though.
Here's a photo of the "My Rails" kit Rolling with laughter
Post #84316 14th Aug 2011 9:50am
WelshGas
Excellent dvi. Thanks a lot. I too had wondered why you had to fit expensive rails to raise the height of the seats. Thumbs Up Thumbs Up LANDYWATCH
Post #84323 14th Aug 2011 10:34am
