Home > Td5 > Intermittent rear wiper gizmo
Page 2 of 3 <123>
landy andy
Just to confirm. If you have a late Defender it will have a relay in the rear door and you just need to swap that with a 99 relay for intermittent wipe.
Is that correct?
Thanks
Andy.
Post #827183 23rd Apr 2020 1:51pm
Martin
Site Admin
Having compared the diagrams side to side, I don't see how it could work as a direct plug in.
Fitting an intermittent timer in place of the rear door relay would connect it up so that the rear wiper button would ground the timer, but the washer input would be ignition powered.
The intermittent pin isn't connected.
So in theory, the timer should operate as if you've got the washer button held down permanently on the front, so it would just wipe continuously. It might not even give the run-on wipes after the button is released, as it ground to the timer would be instantly cut which might just stop everything in its tracks.
That said, I've not tried it!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #827201 23rd Apr 2020 3:16pm
landy andy
Ohhh. My head hurts.
On mine the wash button doesn’t have any effect on the wipe function.
Just for clarity my Td5 is an 06 model.
Post #827202 23rd Apr 2020 3:21pm
Martin
Site Admin
On the back they don't - the wash and wipe (as standard) are separate and simply on or off.
I was referring to how the front works, looking at the wiring if you plugged a timer into the rear door it would work in the same way as the front washers work as standard.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #827203 23rd Apr 2020 3:23pm
landy andy
Ahhh. Ok thanks, that makes sense.
May just get one and give it a go. Thumbs Up
Post #827204 23rd Apr 2020 3:24pm
Martin
Site Admin
You can always pinch the front timer and stick it in the back.
The VW99 relay is just a programmable/variable version of the one LR used in the front wiper system.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #827206 23rd Apr 2020 3:25pm
landy andy
Yes. Think I’ve got a spare off an old defender in the garage.
Post #827207 23rd Apr 2020 3:27pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Plug and play. Just swap out the relay for the VW relay in the rear door.
Turns the wiper in to an intermittent wiper. Completely separate to the washer.
Once installed, switch on rear wiper on dash and the rear wiper is now intermittent. 2007 TD5 90 Hard Top
Post #827215 23rd Apr 2020 3:51pm
Martin
Site Admin
Can't understand how it works given the pinout but there we go!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #827216 23rd Apr 2020 3:51pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
I think my head has just exploded 🤯
I have just ordered the park switch for the rear as tha5bwasnt working, and was hoping to do this mod at the same time ,
Can it be done by someone else from a safe distance from anyone ? Rolling with laughter
I’m still happy to pay for a pre wired relay with a very clear wiring diagram if anyone wants to adblige Thumbs Up
Post #827218 23rd Apr 2020 3:52pm
Landlord
Just to clarify - Mine is a MY 07 TD5 so presuming Landy Andy's 06 is the same. Your probably right Martin pre 02 models / older doors have a different set up.
Without taking the door card to check my instal - one of the terminals may have had to have had the wire swapped over - however it was an easy job as per the instructions posted before. 2007 TD5 90 Hard Top
Post #827221 23rd Apr 2020 3:58pm
Martin wrote:
I’ve developed a rear wiper wizard Laughing which varies the number of wipes on the back and wipes when washing etc.
It’s not plug and play at the current time but it’s all wired at the rear wash/wipe switches and front wiper timer.
https://www.defender2.net/shop/defender-re...-p108.html
However it’s for the 2002 model on Sad
Martin, can you give us some more info about what this thing looks like and how it's installed? Your shop page is a bit light on detail! It could be just the thing I need to support another little project. Darren
Post #851849 25th Aug 2020 9:07am
Martin
Site Admin
I'm sorting a video now Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851858 25th Aug 2020 9:53am
Sounds exciting Very Happy Darren
Post #852102 26th Aug 2020 10:46am
Martin
Site Admin
It would have been great if the mic I was using wasn't all muffled. I've had to re-record the audio, trying to sync it up Banging Head  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #852105 26th Aug 2020 10:51am
Page 2 of 3 <123>
