![]() | Home > Td5 > Intermittent rear wiper gizmo |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726
Having compared the diagrams side to side, I don't see how it could work as a direct plug in.
Fitting an intermittent timer in place of the rear door relay would connect it up so that the rear wiper button would ground the timer, but the washer input would be ignition powered. The intermittent pin isn't connected. So in theory, the timer should operate as if you've got the washer button held down permanently on the front, so it would just wipe continuously. It might not even give the run-on wipes after the button is released, as it ground to the timer would be instantly cut which might just stop everything in its tracks. That said, I've not tried it! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
Ohhh. My head hurts.
On mine the wash button doesn’t have any effect on the wipe function. Just for clarity my Td5 is an 06 model. |
On the back they don't - the wash and wipe (as standard) are separate and simply on or off.
I was referring to how the front works, looking at the wiring if you plugged a timer into the rear door it would work in the same way as the front washers work as standard. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Ahhh. Ok thanks, that makes sense.
May just get one and give it a go. |
You can always pinch the front timer and stick it in the back.
The VW99 relay is just a programmable/variable version of the one LR used in the front wiper system. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Yes. Think I’ve got a spare off an old defender in the garage.
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Plug and play. Just swap out the relay for the VW relay in the rear door.
Turns the wiper in to an intermittent wiper. Completely separate to the washer. Once installed, switch on rear wiper on dash and the rear wiper is now intermittent. 2007 TD5 90 Hard Top |
Can't understand how it works given the pinout but there we go!
2015 D90 XS SW |
| Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845
I think my head has just exploded 🤯
I have just ordered the park switch for the rear as tha5bwasnt working, and was hoping to do this mod at the same time , Can it be done by someone else from a safe distance from anyone ? I’m still happy to pay for a pre wired relay with a very clear wiring diagram if anyone wants to adblige |
Just to clarify - Mine is a MY 07 TD5 so presuming Landy Andy's 06 is the same. Your probably right Martin pre 02 models / older doors have a different set up. Without taking the door card to check my instal - one of the terminals may have had to have had the wire swapped over - however it was an easy job as per the instructions posted before. 2007 TD5 90 Hard Top |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Martin, can you give us some more info about what this thing looks like and how it's installed? Your shop page is a bit light on detail! It could be just the thing I need to support another little project. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I'm sorting a video now
2015 D90 XS SW |
Sounds exciting
It would have been great if the mic I was using wasn't all muffled. I've had to re-record the audio, trying to sync it up
2015 D90 XS SW |
