![]() | Home > In Car Electronics > Split Charge Fuses |
buckers19 Member Since: 02 Jan 2018 Location: London Posts: 95 ![]() ![]() |
After a number of issues with my split charging system, I’ve narrowed it down to the circuit breakers/fuses.
I’ve struggled to find what means of protecting the system people are using, but is it necessary to use circuit breakers like these: https://www.12voltplanet.co.uk/waterproof-...akers.html Or can I use a maxi fuse which will be considerable cheaper. Keen to hear people’s thoughts Instagram.com/mattbuckley19 |
Sorry, should have clarified.
The fuses I need to replace are between the main battery and aux battery. They’re the fuses either side of the voltage sensing relay. Instagram.com/mattbuckley19 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
I just have a 100 amp strip fuse (I don’t know the proper name) at each end of the live between the two batteries. They’ve never given any trouble. 2007 110 TDCi Station Wagon XS
It depends, to an extent, on the capacity of your split charge relay and wiring. When I built mine, I used 110 amp cable and 100amp maxi fuses either side of the VSR:
![]() Click image to enlarge (Ignore the yellow 60 amp fuse - that's not related.) Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
LRA, that's a very clean setup, does that fit in the battery box with 2 batteries? Instagram.com/mattbuckley19
Yes, just about:
![]() Click image to enlarge The two vertical threaded rods are for the battery clamps. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
