Home > Off Topic > My RRC project
Page 45 of 53 <123 ... 444546 ... 515253>
Procta
yeah thats look ok Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #825288 14th Apr 2020 7:17pm
I imagine that in order to maximise the benefit of the manifolds you'd also have to port the heads to match the manifold. That should make an appreciable performance difference.
Post #825318 14th Apr 2020 8:13pm
grafty99
Its a fully John Eales built Griff 500 5.0L V8.
So, Off the top of my head work done includes;
Fully blueprinted,
Dynamically balanced,
Cross bolted
Later serpentine front end (inc improved oil pump),
Stage 4 big valve ported & gas flowed heads,
Fully machined trumpet base and inlet tracts (port matched),
Custom high torque cam by JE
Fully hand formed trumpet flares
and now JE big bore cast manifolds (also gasket matched)
and probably some I've missed!
It originally had a full Janspeed system on it , but the mild steel headers didn't cope well with a life near the sea! That system was replaced by an off the shelf stainless affair in the early 2000's (not long before it was decommissioned).
The generic stainless jobbie seriously hampered performance, being only (poorly) designed for a 3.5. Hopefully the system I'm building will allow it to breath, again, as it once did Mr. Green
After the mandatory start up with only headers on (to check for exhaust gas leaks obviously Whistle ) I can certainly say that it revs much more freely than it did with just the generic stainless headers on Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #825360 14th Apr 2020 9:46pm
grafty99
Small update today, I forgot to take pictures when it was fully welded, but hopefully over the weekend I'll get the system close to finished Mr. Green
1990 Vogue SE
Post #825867 16th Apr 2020 8:21pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Another great job you’re doing with this RRC, please let us have a soundtrack once it’s completed Thumbs Up cheers Paul
Post #825883 16th Apr 2020 8:55pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Did you discuss your plans to have no X/Y merge piece with John E when you bought the engine?
Post #825952 17th Apr 2020 9:23am
grafty99
Thanks Paul Bow down
The original conversion was done in the late 90s so no, not at the time. If unbalanced pipes don't suit it then I can very easily fit a H pipe Thumbs Up
(I'm not keen on the sound of X pipes and apparently H pipes are better for low down torque Thumbs Up) 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #825979 17th Apr 2020 12:58pm
grafty99
Took the Range Rover for a drive around the site today (with the exhaust finished apart from the rear silencers).
The conclusion from this highly scientific experiment is that two fold.
Firstly, it sounds simply sublime - just what I'd hoped for. Cool
Secondly, traction (on an unsealed road) is now a problem up to about 60mph Shocked
So all in all, a very satisfying job so far! When I've got the silencers fitted and linked up I'll do full photos and a video Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #826612 20th Apr 2020 7:04pm
Procta
I have heard these can wheel spin Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #826705 20th Apr 2020 10:54pm
grafty99
Mine now spins all 4 very easily around the site, it didn't before! Not scientific I know but it must be putting more power down to do that. The viscous centre diff in the RRC is 60/40 power split to the rear believe and also effectively limited slip as the diff locks when there is wheel spin front or rear Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #826708 20th Apr 2020 10:57pm
Procta
It will be, i remember the SPi to MPi days, the lads used to convert the SPi cars to MPi so they could get more power etc. ECU, injection system and exhaust etc swop over.
Anyway when i bought my GTA 16v SPI, the owner looked into MPi converting the car, but couldnt really get the earlier bits. But fitted the MPI manifold and he found that it made a hell of a difference over the SPI stuff, He told me it could have been pushing 100+ bhp, with the MPi manifold. They were about 90 bhp with the spi manifold on. I finished the conversion but that's another story Rolling Eyes So a good decent exhaust really makes the difference Thumbs Up My HDI has a Power flow system on and that opened the car up. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #826711 20th Apr 2020 11:15pm
grafty99
Picture of the finished exhaust, the only thing left to do is the tips. I'm thinking simple 3 inch rolled out tips Thumbs Up
Video to follow Whistle
1990 Vogue SE
Post #827583 25th Apr 2020 2:02pm
Barneyboy
Very nice Thumbs Up cheers Paul
Post #827586 25th Apr 2020 2:19pm
grafty99
Here's the video - hopefully the sound comes out ok Thumbs Up
1990 Vogue SE
Post #827618 25th Apr 2020 4:44pm
Barneyboy
Cool Thumbs Up Nice Thumbs Up cheers Paul
Post #827710 26th Apr 2020 7:56am
