![]() | Home > Maintenance & Modifications > Hand Brake Shoes?...anyone done? |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Split the exhaust at the joint just in front of the silencer. This will allow enough room to pull it out the way enough to get it off. Hold my beer and watch this!
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1272 ![]() ![]() |
Cheers... guessed so.
Don’t fancy that for now..maybe after lockdown ![]() Clemmo |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Has the hand brake ever been set too close and been binding?
I've never even thought about changing a set! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8376 ![]() ![]() ![]() |
They are not an item usually changed due to wear, more likely contamination.
Can you not undo the exhaust rubbers to let it drop enough? If not split as above. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
