Home > Td5 > Air in Fuel After Filter Change
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I took the opportunity of all this spare time to service my Td5 last week. As part of that I changed the fuel filter and ran the obligatory fuel bleed. I’ve only driven it twice since and each time the pump has made the telltale gurgle of there being a bit of air. I started it a short while ago, having not moved it for a few days, and it was not happy when it started. It was really lumpy so I shut it off. Started it up again straight away and it was fine.
Is there just a tiny bit of air left that’ll work it’s way out or has something failed such as the filter housing? There are no obvious signs of any diesel leaks.
Cheers! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #822933 2nd Apr 2020 12:59pm
rallysteve
if you didnt pre-fill the new filter with diesel it will take a little while to bleed all the air out of the filter.
I never bother pre-filling the new one to be honest. I normally find two bleed cycles and about an hour of driving and any sign of air will have gone.
Post #822946 2nd Apr 2020 2:41pm
BaronDefenders
No I didn't pre-fill the filter. I was more concerned with the lake of diesel I'd created on the drive Whistle
I only did one purge cycle as well so there probably was a fair bit of air left in the system.
I'll keep an eye on it but hopefully it's all good now that I've just driven it into Ciren and back. Charlie
2002 Td5 90 (SOLD)
Post #822947 2nd Apr 2020 2:50pm
excossack
I don't pre-fill the filter either. Just turn on the ignition make sure the pump whirls away and then for a brew and come back when its stopped,. Start up and done. No issues. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #822959 2nd Apr 2020 4:12pm
landy andy
What make of fuel filter did you fit?
Post #823012 2nd Apr 2020 8:32pm
BaronDefenders
It’s a Mahle filter. Charlie
2002 Td5 90 (SOLD)
Post #823013 2nd Apr 2020 8:33pm
apachecow
1999 Defender 110 Td5 CSW Rutland Red
You did check that the central washer hadn't become stuck to the housing? It's possible to accidentally double them up and then you don't get a great seal.
Post #823236 3rd Apr 2020 10:24pm
BaronDefenders
Hmmm I didn’t check actually. I don’t think it did though. I might still have the old filter in the bin so I’ll look at it tomorrow. Charlie
2002 Td5 90 (SOLD)
Post #823237 3rd Apr 2020 10:33pm
BaronDefenders
Just driven to the village shop and all is now fine. Must have just been air leftover in the system. Lesson learned, purge it twice. Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #823862 7th Apr 2020 11:59am
