![]() | Home > Td5 > Air in Fuel After Filter Change |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
if you didnt pre-fill the new filter with diesel it will take a little while to bleed all the air out of the filter.
I never bother pre-filling the new one to be honest. I normally find two bleed cycles and about an hour of driving and any sign of air will have gone. Steve 02' 110 TD5 Double Cab Rebuild Thread |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
No I didn't pre-fill the filter. I was more concerned with the lake of diesel I'd created on the drive
![]() I only did one purge cycle as well so there probably was a fair bit of air left in the system. I'll keep an eye on it but hopefully it's all good now that I've just driven it into Ciren and back. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
I don't pre-fill the filter either. Just turn on the ignition make sure the pump whirls away and then for a brew and come back when its stopped,. Start up and done. No issues. 1999 Defender TD5 110
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5980 ![]() ![]() |
What make of fuel filter did you fit?
It’s a Mahle filter. Charlie
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 ![]() ![]() |
You did check that the central washer hadn't become stuck to the housing? It's possible to accidentally double them up and then you don't get a great seal.
Hmmm I didn’t check actually. I don’t think it did though. I might still have the old filter in the bin so I’ll look at it tomorrow. Charlie
Just driven to the village shop and all is now fine. Must have just been air leftover in the system. Lesson learned, purge it twice.
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
