|  | Home > Td5 > What type of paint is used on TD5 ? |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142    |
 My 2003 TD5 CSW needs a bit of bodywork sorting out. and will need some respraying. Now I have plenty of time on my hands, and have the basic equipment to spray, in need to know what paint system is used.
 It’s a CSW in a lovely deep shiny Oslo blue. It’s obviously got a clear coat on top because it’s peeled on one of the wing tops. I’ve done loads of coach enamel spraying on my Series, but never tackled a modern vehicle other than with touch up rattle cans. This needs a bit more than that. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy | ||
|  29th Mar 2020 2:15pm |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142      | Water-based acrylic polyurethane as the base followed by 1k or 2k clearcoat. Or you could get the paint supplier to mix a solid colour which will gloss straight out of the gun and will not need a clear coat. I tend to use solid colour these days (unless its Metalic paint)as its a lot less hassle.) For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
 http://www.youtube.com/user/conwy1 | ||
|  29th Mar 2020 2:23pm |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142      | As said a mask is imperative. However, as you will not be spraying every day you could use a good carbon-filled mask and spray outside or in a garage with plenty of ventilation. Also, wear goggles as you do not want isocyanates. in your eyes For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
|  29th Mar 2020 3:21pm |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142      | You could also test a small sample of paint to see if you can get away with Celly the easiest paint to spray high gloss and drys in seconds, and is non-cancerous, make a mistake and just sand down within minutes or if you get a paint reaction with celly on your original paint you could spray a water-based barrier coat and use celly on top of that. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
|  29th Mar 2020 3:26pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060    | Good luck getting a face mask    | ||
|  29th Mar 2020 4:52pm |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731      |  Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... | ||
|  29th Mar 2020 4:55pm |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142    | Hmmm ok, I think it might have to go to a pro. Don’t like the sound of the clear coat poisoning me. I have a decent mask but it’s not air fed. 2021 Defender 110 X-Dynamic HSE D300 MHEV
|  29th Mar 2020 8:15pm |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341      | You can get single pack acrylic clearcoat which is less toxic. I'm going to be spraying some in my garage this week. Should still use a decent mask though. 2007 110 TDCi Station Wagon XS | ||
|  29th Mar 2020 9:19pm |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142      | 1k clear coat is Ok but it needs heat applied for it to cure otherwise it takes an age to fully harden.
 Do not be put off having a go yourself the chance of catching cancer by spraying a few LR panels wearing a good mask is incredibly low. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 | ||
|  29th Mar 2020 9:35pm |
| deftd5 Member Since: 26 Dec 2018 Location: worcester Posts: 15      | All valid points above, but bare in mind nothing will give the durability or quality of the 2 pack systems. | ||
|  30th Mar 2020 9:21am |
| Posting Rules
