![]() | Home > In Car Electronics > Rear LED work lights.... |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2239 ![]() ![]() ![]() |
I have some Vision X Dura minis on the back of my 110. For the price, very unimpressive.
Also have some of those 18W LED ones on the sides of my 110 and on the back of the 90's cage. They are great little lights, especially for the money. I would recommend getting the 'WOWLED' branded ones as they seem to have superior sealing and better longevity Also change the stainless fasteners they come with for good ones as they don't last well I cut the cables on them shorter and fit either superseal connectors or Deutsch DT connectors to them. Steve 02' 110 TD5 Double Cab Rebuild Thread |
I've had these Rigid Industries on for 8 years. Great output and never had an issue:
![]() Click image to enlarge They were, however, stupidly expensive (as copies weren't available at the time). e.g. https://www.ebay.de/itm/Rigid-Industries-S...SwVEdbQbBP Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1478 ![]() ![]() ![]() |
I made this aluminium bracket to avoid drilling mounting holes in a panel. It still needed a small grommet through the roof for the wire though. ![]() Click image to enlarge That light is the second one that's been on there, the first one corroded. This one is branded WOW LED, bought off eBay, great for only £8. |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
There are lots of ways of mounting lights that don't require any drilling - CB aerial gutter mounts are good option - but there's always the issue of getting the cable inside. I'm not a fan of passing cable through door seals so holes and glands were the only practical option. Darren
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
Perfect, thanks. Just ordered them. |
RR08 Member Since: 25 Mar 2009 Location: Somerset Posts: 39 ![]() ![]() ![]() |
How did you run the cable ?
The cable goes through the roof, near the gutter corner.
If the light ever comes off, it will only need a single small blanking grommet to fill it. It then drops down behind the rear window trim, with switch in the speaker panel. Connects to the commonly used purple wire, permanent live. ![]() Click image to enlarge |
