Home > In Car Electronics > Rear LED work lights....
Page 2 of 2 <12
90 Dreamer
I keep looking at various options like that but have no wish to drill the panels so unsure of any other mounting options??
Post #821991 29th Mar 2020 11:12am
rallysteve
I have some Vision X Dura minis on the back of my 110. For the price, very unimpressive.
Also have some of those 18W LED ones on the sides of my 110 and on the back of the 90's cage. They are great little lights, especially for the money. I would recommend getting the 'WOWLED' branded ones as they seem to have superior sealing and better longevity
Also change the stainless fasteners they come with for good ones as they don't last well
I cut the cables on them shorter and fit either superseal connectors or Deutsch DT connectors to them.
Post #821992 29th Mar 2020 11:15am
ZeDefender
I've had these Rigid Industries on for 8 years. Great output and never had an issue:
They were, however, stupidly expensive (as copies weren't available at the time).
e.g. https://www.ebay.de/itm/Rigid-Industries-S...SwVEdbQbBP Tell someone you love them today because life is short.
Post #822010 29th Mar 2020 12:15pm
DSC-off
I made this aluminium bracket to avoid drilling mounting holes in a panel.
It still needed a small grommet through the roof for the wire though.
That light is the second one that's been on there, the first one corroded.
This one is branded WOW LED, bought off eBay, great for only £8.
Post #822048 29th Mar 2020 2:32pm
There are lots of ways of mounting lights that don't require any drilling - CB aerial gutter mounts are good option - but there's always the issue of getting the cable inside. I'm not a fan of passing cable through door seals so holes and glands were the only practical option. Darren
Post #822088 29th Mar 2020 5:20pm
LandRoverAnorak wrote:
Here you go:
https://www.ebay.co.uk/itm/18W-cree-LED-Wo...pCJSZZd8tw
Perfect, thanks. Just ordered them.
Post #822094 29th Mar 2020 5:44pm
RR08
United Kingdom 2010 Defender 110 Puma 2.4 USW Cairns Blue
How did you run the cable ?
Post #834543 1st Jun 2020 11:30am
DSC-off
The cable goes through the roof, near the gutter corner.
If the light ever comes off, it will only need a single small blanking grommet to fill it.
It then drops down behind the rear window trim, with switch in the speaker panel.
Connects to the commonly used purple wire, permanent live.
Post #834684 1st Jun 2020 8:56pm
Page 2 of 2 <12
