![]() | Home > In Car Electronics > 2003 Defender 90 - replacing the original aerial |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 782 ![]() |
Hi Neil,
Welcome to the forum. I did this exact job yesterday on my 09 plate 130” On the 2.4 puma you can get to the aerial from the engine bay rather than the wheel arch, not sure about on the Td5. I tied the bonnet back as far as it would go with a ratchet strap. The aerial is held by a chrome nut at the top and a spring clip at the lower end. I cut the old cable in the engine bay and taped the new plug to it, it must be in line as the plug will only just fit through the bulkhead hole. I then eased it through the bulkhead by pushing from the engine side. Once through I then pulled the cable from the cab side, plugged in and refitted the radio. It should be easier inthe Td5 as you won’t have the air on ducting and steel strengthening bar to get in the way behind the dash. Andrew |
rustyredwreck Member Since: 16 Jan 2020 Location: Oxfordshire Posts: 24 ![]() ![]() ![]() |
Thanks for the reply Andrew,
I think I'll abandon any idea of accessing up through the wheel arch - a further inspection suggests it would be of limited (if any) benefit. I have completed a dry run and been able to remove the aerial "retaining" nut from the top of the wing. There appears to be some type of clip on the underside of the wing which helps to keep the aerial in place when the retaining nut is removed - so the aerial can be wiggled from side to side. So far, so good. The left hand side of the engine bay is very congested - I have the servo-assembly and possibly the ABS modulator in the way (I've just looked this up in the parts manual - too dark outside to go and have a look). I cannot actually reach and touch the aerial housing as it sits beneath the wing. Did you have this problem at all? Thanks again, Neil |
Access in the Td5 is obviously harder. You will have to get in there somehow as the aerial has to come out from the underside, not up through the wing.
Hopefully someone who has done the job on aTd5 will come along with some advice. |
I think that the only way to remove it would be from underneath by removing the plastic wheel arch liner. Not a five minute job, unfortunately. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
Possibly a daft question, but in what way is a Td5 different to a TDCi, I thought the wings were the same?
Is it the air intake that makes the difference? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Done a good few of these on Td5’s and a Tdci. They are both basicly the same and it is easily all done from above, even with abs/TC unit in place
Just undo the chrome on the top, that will allow it to drop, it is the in a hook clip further down but will pop out of that as you now extract it upward. Cut cable on old and tape new cable to it, then pop out clock binnacle, find wire and start to pull it through. A good spray with Teflon lub helps. Then pull through to head unit. |
deftd5 Member Since: 26 Dec 2018 Location: worcester Posts: 15 ![]() ![]() ![]() |
Yep just had a look at my Td5 with abs, you can get your arm up under the brake servo. Definitely doable from the top.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
As Landy Andy says, it's best to use a cable pulling lubricant to avoid damaging the insulation. Screwfix and similar tool shops normally stock it. Defender 90XS SW
As described in my post I taped the plug to the old cable and then pushed/fed it through from the engine bay.
It’s a reasonably tight fit but went through easily enough without lubrication. |
Thanks all for the responses, suggestions and help.
I'll be having a go at replacing the aerial later in the week. I'll post a final comment on how it went mid next week to close the thread out. Having successfully fitted a new 2DIN console and head unit during the week I am getting quite bold in my ambitions. I thought replacing the aerial would be simple - it's obviously been a while since I owned my previous land rover and I'd forgotten that nothing is ever as simple as you might expect. Thanks again and keep healthy all, kind regards Neil |
Finally managed to getting around to fitting the new FM aerial.
First things - my fat arm wouldn't fit in the engine compartment to get to the old aerial out without removing what the parts manual calls the fender bracket (which required the removal of two screws). Easy enough and nothing else fell off when it was removed. Old aerial out without a problem - but a clip which held the base of the old aerial snapped off - doesn't appear to have made a massive difference now the new aerial is in - the new aerial remains vertical. I followed the advice given earlier and taped the new aerial cable to the old to pull though the bulkhead - and, even with the liberal application of lubrication, the old cable snapped. However.... I undid 5 screws on the lower dash (having already unscrewed the instrument binnacle and upper dashboard) and this gave me enough room to play with to gently pull the new cable in once I'd gently pushed the new cable in from the engine bay. Undoing the lower dash made such a difference and, based upon my experience, I would recommend it. Plugged the aerial into the stereo and I now have a better FM signal than I do a DAB signal. Happy days. Thanks again all for the advice. Kind Regards Neil |
Sleonard73 Member Since: 15 Sep 2022 Location: Northern Ireland Posts: 1 ![]() ![]() ![]() |
Is there any chance you took a picture of where the aerial cable goes through the engine firewal from the engine side?
I'm about to attempt this minor surgery on my Defender 90 Puma 2.2 and the engine bay is particularly busy around the aerial. Stephen ... |
Paddington Member Since: 15 May 2020 Location: Oxford Posts: 43 ![]() ![]() |
I'll take a photo later and post. Kind Regards Neil
