Home > Puma (Tdci) > Change propshaft ?
XanaX
France 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Change propshaft ?
Hi!
I live in France and buy a second hand defender TD4 2,2
Actually 40 000 km.
I decide to make service my self ( before Land Rover make it)
Today i have grease UJ and when i want to grease Defender Front and Rear Propshaft. I see any Grease Points. There are no recall in France for this matter...
Can i wait to change the propshaft or should i change quickly ?
Thanks and sorry for my english.
Post #821905 28th Mar 2020 11:04pm
landy andy
Are you saying that there are no grease nipples (point to inject grease in) on the prop shafts?
Normally there are three grease points per prop shaft. One in each universal joint, between yoke, and one on the slider.
What have you got on yours?
Andy.
Post #821919 29th Mar 2020 12:17am
There was a UK service bulletin to replace propshafts where the nipples were not fitted.
There's no need to replace the propshaft simply because it has no grease nipples. It is probably worth seeing if you can fit one on the splined sliding joint (the hole should be there) since wear means a new shaft. The UJs may or may not be drilled for nipples (fit them if drilled) but at least UJs are easy to replace.
There's no need to replace anything if it isn't worn, so even without any nipples you can use it till it wears.
Post #821937 29th Mar 2020 8:37am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
I have one prop shaft with nipples and one without which confused the hell out of me until about 2 minutes ago Laughing
Post #821939 29th Mar 2020 8:41am
XanaX
Andy.
I have only grease point on each UJ. Any grease pount on the slider
Post #821955 29th Mar 2020 9:29am
Check in that case whether the shaft is drilled for the missing nipple (the hole may be missing, or plugged). If you have the hole, fit a nipple. If you don't, replace the shaft when the splines become worn.
Post #821967 29th Mar 2020 10:07am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
If anyone has access to this Service Bulletin could they post it on here?
My 2015MY 110 only has grease nipples on the UJ yokes.
Sounds like a nice little Sunday lockdown project in the sun!
Post #822001 29th Mar 2020 11:44am
SSM40851
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender
Title: Defender Front and Rear Propshaft Grease Points
Last Modified: 30-MAR-2009 08:27
Category: Noise/ Vibration
Symptom: 703000 Vibration Concerns
Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees.
Post #822052 29th Mar 2020 2:53pm
XanaX
I have check and the shaft is not drilled.
So i suppose i will wait a for more km and change it at this time.
Post #822058 29th Mar 2020 3:25pm
Marks Landy
Thanks Blackwolf!
The Service Bulletin was dated March 2009 and they still continued making new vehicles with the same problem for 6 years.
Post #822096 29th Mar 2020 5:52pm
And you're surprised?! Rolling with laughter
Post #822137 29th Mar 2020 8:00pm
Mine had exactly this. A grease nipple on a UJ on each prop missing. It was one if these the rearmost that failed.
Never had any contact regarding a recall or anything.. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #822168 29th Mar 2020 9:46pm
XanaX
Very Funny ! Laughing
Post #822423 30th Mar 2020 10:48pm
Dinnu
Since i bought my 2012 90, i wanted to take out the rear prop shaft to align the yokes, but was always too scared that i could mess up the balancing... right now i do not feel any vibrations. My earlier knowledge on older defenders was that only the front prop shaft have a shift in angels between the yokes, due to tge front pinion not being horizontal.
While doing some job on a family defender, i noticed that his rear prop shaft also have a phase shift between the yokes. Got on Paddocks site, and in their part picture, the same phase shift is present between the 2 yokes.
Any one knows why this was done, given that rear diff pinion and transfer case output seem to be parallel enough to me!!
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #827255 23rd Apr 2020 6:57pm
Yes, it's because the engine and gearbox in the TDCi is nose-up, and as a result the transfer box output flange and the rear diff flange aren't coplanar. The skewed yokes compensate for the lack of parallelism. If you align the yokes you will introduce a vibration.
Post #827265 23rd Apr 2020 8:07pm
