Home > Puma (Tdci) > SOS puma 2.4 won’t start in outback
Devomorris
Brunei 1984 Defender 90 V8 Petrol CSW Auto Chawton White
2008 tdci 2.4 puma auto won’t start.
Stopped at fuel station and refilled, on starting, nothing happened.
Eventually, it would turn over briefly, but not start. No power to starter. Turn everything off, wait (relay clicks off), the same happens. Have shorted starter relay, starter work’s continuously, shorted the main power relay, same thing happens.
Is there something in the ecu that’s shutting down.
BAS scan tool locked “P068A engine control module relay de energised early”
Had just come out of the desert with very corrugated roads, maybe something has worked itself loose.
Not sure where to go now
Any advise appreciated.
Post #821121 25th Mar 2020 1:54am
Are battery terminals tight? Check all Relays are secure and not loose.
Check battery Ground is not loose and if you have torx bits check IPAC. instrument cluster plug is secure to the rear.
If battery has been disconnected, make sure you press alarm fob multiple times fast until locked or unlocked as this re-syncs the system otherwise the immobiliser will cut the engine after turning over.
Also press unlock just before you go to turn her over as that should ensure no immobiliser interpherence, make sure the fob is with the key too.
Hope that helps, abs some things I would try. Thumbs Up
Good luck. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #821123 25th Mar 2020 2:27am
hank
I'm no expert on no-start issues but this might offer a good starting point https://www.defender2.net/forum/topic59938.html > 110 XS Double Cab
Post #821153 25th Mar 2020 9:34am
The first thing I would check is that the main and starter relays (under the seat) both have really secure connections, loose connections on these is a very common Puma problem.
The second thing I would try, if the first didn't solve the problem, is disable the passive immobiliser and see if that makes a difference. The PI is not particularly robust and can cause all manner of issues.
Post #821182 25th Mar 2020 11:05am
Devomorris
I’ve enlisted the help of Pete Bell to sort out, what appears to be an immobiliser issue. Watch this space
Post #821215 25th Mar 2020 1:31pm
Martin
Site Admin
https://www.defender2.net/forum/topic71654.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821220 25th Mar 2020 1:48pm
Devomorris
Turned out to be an immobiliser problem. Pete sent me a new map which by passes the immobiliser and hey presto, started straight up. Should never happen again.
Post #821891 28th Mar 2020 10:27pm
Martin
Site Admin
I bet it was actually the instrument pack socket issue not letting the immobiliser signal through to the ECU. You mention rough roads just before the problem.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821896 28th Mar 2020 10:48pm
Devomorris
Yes, I think you might be correct.
Sorted now...... for good.
Post #821906 28th Mar 2020 11:06pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
The immobiliser on my 2.4 scares the bejesus out of me. I am even too sacred to disconnect the battery. Mines a daily driver and I park in public parking so I cant be fanning around with this. Is there a mod that I can do before I have a problem? (I don't know Pete)
Post #821946 29th Mar 2020 8:58am
Devomorris
Pete Bell from Bell Auto Services (BAS). Google his web site. Bit of a guru with Land Rover remapping
Post #822025 29th Mar 2020 12:50pm
90 Dreamer
If your that worried could you not get another ECU modded ready and keep iit as a spare??
Post #822029 29th Mar 2020 12:53pm
Martin
Site Admin
https://www.defender2.net/forum/post814212.html#814212  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #822457 31st Mar 2020 9:36am
Mcmuffin
Belgium 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Look for a burned fuse on door lock position in the fuse box
Disconnect the doorlock loom of both second row doors. L and R in the pillar next to the seat, near the floor is a hole in the pillar.
Replace the fuse
Try to start the engine
Post #822667 1st Apr 2020 9:22am
SGoggin
Just one thing too. In Australia, some service stations have some sort of wireless connection ( I think it was for the pump readings but not sure) but this interferes with the immobilizer on the PUMA's. You'll notice the red LED on the dash flash oddly.
Can be fixed by pushing the defender round the corner!
Post #825691 16th Apr 2020 3:16am
