![]() | Home > Puma (Tdci) > SOS puma 2.4 won’t start in outback |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20844 ![]() ![]() |
Are battery terminals tight? Check all Relays are secure and not loose.
Check battery Ground is not loose and if you have torx bits check IPAC. instrument cluster plug is secure to the rear. If battery has been disconnected, make sure you press alarm fob multiple times fast until locked or unlocked as this re-syncs the system otherwise the immobiliser will cut the engine after turning over. Also press unlock just before you go to turn her over as that should ensure no immobiliser interpherence, make sure the fob is with the key too. Hope that helps, abs some things I would try. ![]() Good luck. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2334 ![]() ![]() ![]() |
I'm no expert on no-start issues but this might offer a good starting point https://www.defender2.net/forum/topic59938.html > 110 XS Double Cab
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17788 ![]() ![]() ![]() |
The first thing I would check is that the main and starter relays (under the seat) both have really secure connections, loose connections on these is a very common Puma problem.
The second thing I would try, if the first didn't solve the problem, is disable the passive immobiliser and see if that makes a difference. The PI is not particularly robust and can cause all manner of issues. |
Devomorris Member Since: 11 Sep 2012 Location: Borneo jungle Posts: 7 ![]() ![]() ![]() |
I’ve enlisted the help of Pete Bell to sort out, what appears to be an immobiliser issue. Watch this space
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6669 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic71654.html
Turned out to be an immobiliser problem. Pete sent me a new map which by passes the immobiliser and hey presto, started straight up. Should never happen again.
I bet it was actually the instrument pack socket issue not letting the immobiliser signal through to the ECU. You mention rough roads just before the problem.
Yes, I think you might be correct. Sorted now...... for good. |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 ![]() ![]() ![]() |
The immobiliser on my 2.4 scares the bejesus out of me. I am even too sacred to disconnect the battery. Mines a daily driver and I park in public parking so I cant be fanning around with this. Is there a mod that I can do before I have a problem? (I don't know Pete)
Pete Bell from Bell Auto Services (BAS). Google his web site. Bit of a guru with Land Rover remapping
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2240 ![]() ![]() ![]() |
If your that worried could you not get another ECU modded ready and keep iit as a spare??
https://www.defender2.net/forum/post814212.html#814212 ![]() ![]() |
Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38 ![]() ![]() ![]() |
Look for a burned fuse on door lock position in the fuse box
Disconnect the doorlock loom of both second row doors. L and R in the pillar next to the seat, near the floor is a hole in the pillar. Replace the fuse Try to start the engine |
SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 ![]() |
Just one thing too. In Australia, some service stations have some sort of wireless connection ( I think it was for the pump readings but not sure) but this interferes with the immobilizer on the PUMA's. You'll notice the red LED on the dash flash oddly.
Can be fixed by pushing the defender round the corner! |
