![]() | Home > Puma (Tdci) > Switch Wiring |
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
The "Aux 2" switch (YUG000540LNF) switches the earth and must be wired-up as designed for the LEDs to light correctly. All you need to know is in these threads - http://www.defender2.net/forum/topic552.html http://www.defender2.net/forum/topic679.html http://www.defender2.net/forum/topic795.html . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| luke11 Member Since: 10 May 2011 Location: Cambridge Posts: 32
I'm a bit confused, i thought i'd done eveything correctly.
The switch is turning the lights on and off as it should, it illuminates when the side lights are on, but the orange indicatoor light is on all the time when connected. Any ideas? |
Could you confirm the part number of the switch you have? And how you have wired it - which wire goes to which pin on the switch? . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
PaulMc gave you several links to look at....Did you read them? Below is a cut and paste from the first link he posted, think all the information being an electrician myself is all there, bits you need, plus a comprehensive wiring diagram...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Treat every day as if it is your last....one day you will be right!! |
I'll need to check on the part number but its an AUX 2 latching light switch, the connections are below Pin 1 - Negative from the LED beacons Pin 2 - Dash lights, taken from pin 2 on another switch Pin 3 - Earth on the bulkhead Pin 4 - Not Used Pin 5 - Permanent 12 Volt fused Thanks Luke |
All looks fine, except for Pin 5 A permanent live on Pin 5, will light the Orange 'Tell-Tale' LED permanently, as you describe. Pin 5 should be powered from the switched positive side of your lamps (see my diagram above), so that it lights only when your lamps have power and are lit. Edit: Re-reading your previous post, you mention LED lamps, I'm guessing that you aren't using a relay in your circuit? If so, then the 'Aux 2' switch, in it's standard form, isn't best suited to your circuit However, all is not lost The switch internals can be easily modified to make it a 'live switching' switch, with all the LEDs working properly. I don't have time to post the details right now, as I'm off out, but I think that I covered it in one of the links I posted previously. In any case, I'll re-post the details here, later . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
OK, here we are It's easy to convert the 'Aux 2' switch YUG000540LNF to a conventional live switching ON/OFF switch by cutting the brass track between the two holes, as marked in red in this next picture - Click image to enlarge On the switches that I've modified, I've used a needle file to gently file away the brass track at this point. By cutting the track at this point, you separate pins 3 & 4 The revised circuit, for your LED lamps (without using a relay), would be as follows - Pin 1 - Incoming Live from Fused Supply Pin 2 - Live from Dash Illumination Pin 3 - Switch Earth (for indicator LEDs) Pin 4 - Switched Live output to LED Lamps Pin 5 - Live in from Switch Pin 4 (for Orange 'tell-tale' LED) You could link pins 4 & 5 inside the switch while you had it apart, by soldering a link across the brass tracks but, on my modified switches, I've just crimped an extra short length of cable into Pin 4 on the connector and looped it round into Pin 5 on the connector. I should have shown how the switch comes apart. The body can be separated by carefully lifting the four tabs (two on each side) on the side of the switch body. It's not necessary to remove the switch cap to do this, even though it's shown removed in this picture - Click image to enlarge Re-assembly is easy, the two halves just 'snap' back together. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Thanks for all of your help Paul, i'll be doing this tonight or tomorrow, you've saved me hours of messing around and blowing fuses
Luke |
Happy to help
Let us know how you get on. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
All sorted! Thanks again, next job is rear work lights mounted to the truckman top with a switch at the rear and in the cab!
To 'double switch' your worklights you need to use two changeover switches, wired like this - Click image to enlarge This is how I've wired them in my 110, but using rocker switches for now, until I finish my 2002 Dash Console and re-wire. It is possible to do 'double switching' using a couple of Defender/Discovery II latching switches, but they have to be modified internally. I'm currently doing this modification to a couple of switches for some rear work lights on my Discovery II. Another, different, way of doing it using Defender/Discovery II Switches, is to use non-latching switches such as the Heated Rear Window or Heated Windscreen switches (with only a slight internal modification Ref: 72802R http://www.polevolt.co.uk/acatalog/info_72802R.html
12 volt latching relay, 25 amp with resistor. CO contacts. Latching relays require a single pulse across the coil to change the state of the contacts. They must be used with momentary switches, as the coil must not be permanently energised. A relay base is not available. Five connections are by 6.3mm spade terminals. A fixing point is provided on the case side. An internal resistor is fitted across the coil to suppress back EMF. Price each: (9 or fewer items) £16.80 (£20.16 Including VAT at 20%) Price each: (10 or more items) £15.75 (£18.90 Including VAT at 20%) . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
