![]() | Home > Puma (Tdci) > Averages - and batteries |
I've got a c-tek (plugged in now as it happens) but I have a tendency to forget / can't be bothered to plug it in regular.
I'm thinking of extending the plug / loop terminals such that the loops are permanently bolted to battery and plug resides under seat for easy connection (would utilise same grommet as for heated seats) ![]() will keep an eye on just how long battery lasts but seems average so far is 2-3 weeks. not sure how such a small drain is possible with alarm and other stuff in 'sleep mode' - I wouldn't be surprised if alarm alone was in excess of 10mA ? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
that's exactly what I have done connector is next to the passenger door, I can close the door on the charger cable and the door seal is happy to allow the door to lock DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
Wouldn't it make sense to measure electricity consumption at rest first? Roughly it then would be possible to calculate the duration with the capacity of battery.... |
That’s a cracking secondary use for the snow cowl ![]() Really not a fan of putting cables in doors and closing them ~ Landrover doors especially. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
I dont worry about cables catching in doors, the gap is massive on most defenders. In fact I am not sure my dog wouldnt climb out through the door gaps if she wasnt so well behaved. Cheers
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3745 ![]() ![]() ![]() |
it would and I should. what are most people seeing as an electrical load when parked up? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Pretty much all Defenders currrent draw at rest parked up varies.
I would say between 12 and 30mA would be pretty typical, you can always test your own Defender with a Multimeter too of course. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1249 ![]() ![]() |
Exactly, no holes needed drilling in the Defender and easy enough to use without any faffing about. 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1311 ![]() ![]() |
One of the Ninetys I bought came with a little solar powered battery maintainer.
Currently on a Series One diesel, just inside the windscreen with the wires going out the door and under the bonnet. Seems to keep the seldom used vehicle and its (two 6 volt) batteries fresh, but of course, you have to park outside. |
That's interesting Charles. I keep the fire engine on charge (maintenance). I fired it up last weekend after having to park it up with no access for about 7 weeks. It started but only just. I guess the cold weather of late did not help. 6 volt batteries are expensive so not keen to replace anytime soon! 1984 One-Ten CSW
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 ![]() ![]() |
For a long storage, you can also disconnect the battery.
