![]() | Home > Maintenance & Modifications > Should I treat/paint new galvanized parts? |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 58 ![]() ![]() ![]() |
If you can, absolutely. Zinc will still corrode over (a long) time, eventually leaving bare steel to rust, so additional protection delays the onset of this. If you paint it now, it can be easier to touch up or repaint at a later date than it is to renew the zinc. I also think paint helps protect the zinc from stone chips, albeit minimally.
If not, it's not going to be the end of the world. You'll still get a much longer lifespan out of a galvanised part than the original one. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
Before you paint it you need to clean it well, you generally also need a special primer as well for galvanised steel DEFENDER 90 TDCI XS,
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8458 ![]() ![]() ![]() |
I wouldnt bother. It will prob do 20years with no problems minimum. Cheers
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2412 ![]() ![]() ![]() |
I do like the appearance of bare galv 😊
![]() Click image to enlarge Don't bother painting. My galvanised door strips are from 1984. No rust. Make sure your take care off your chassis where the crossmember is covering the chassis. My 2001 chassis is in a good shape except where the crossmember is sitting. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
NineCherries Member Since: 10 Aug 2019 Location: Falkirk Posts: 59 ![]() ![]() ![]() |
Magic, thanks for taking the time to reply.
I'll treat the chassis below the crossmember for sure. I was going to treat as much of the chassis as i can thats exposed when i have the floor up too. Appreciate the advice. ![]() |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
There's lots of good (British) stuff for chassis treatment here:
www.bilthamber.com |
