Home > Wheels & Tyres > BF Goodrich KM3 MT |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 559 |
Cheers, thank you.
Sounds like they might be the way to go |
8th Mar 2020 5:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
Credit goes to Blackwolf on here as he advised me first and I agree once I had the same that the 255’s are very good in that size. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Mar 2020 5:37pm |
The only slight thing that’s puts me off them is the sidewall bulge with them on 6.5” wolfs.
8th Mar 2020 5:56pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 512 |
In point form answers are : 1. That is comparing a 265/75 to a 255/85. A 265/75/16 is the same diameter as a 235/85 - the image therefore shows the difference between the overall diameter of the two and is representative of a 235. 2. No rubbing in the arches at all. 3. Slight rubbing on radius arms, either live with it or adjust the stops. 4. No loss in power - however I have the lower ratio 1.6 transfer box and not the 1.4 or 1.2. She zips through the gears and will leave quite a few drivers surprised and will also pull from 25/30 mph in 5th with no labouring 5. She tops out at an indicated 85 on the speedo, but the acceleration for a Land Rover is astonishing due to the high output of the 300 and the lower ratio transfer box 7. The sidewall bulge is fine on the 6.5 Wolf Rims and fall well within the recommended rim size for a 255 2017 Range Rover L405 Vogue SE V8 Diesel #16 Land Rover 110 300 TDI |
8th Mar 2020 7:53pm |
Many thanks for taking the time to answer my questions, greatly appreciated
5 x 255/85/16 km3’s now ordered! |
8th Mar 2020 9:21pm |
8th Mar 2020 9:30pm |
You won’t regret it 2017 Range Rover L405 Vogue SE V8 Diesel #16
8th Mar 2020 9:40pm |
I’m still on KM2’s and will be for a long time and very happy with those. In future it will be KM3’s though.
Up until recently I was not holding my breath on ever seeing a 255/85 KM3. Perhaps the enquiries that I and probably many others have made over a period of time did indeed bear fruit. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Mar 2020 9:45pm |
Thanks chaps, will be a while until I get them fitted as just starting a strip down and rebuild!
8th Mar 2020 10:06pm |
Fresh rubber delivered today, can’t wait to see these on
Click image to enlarge |
11th Mar 2020 3:51pm |
11th Mar 2020 5:06pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
Still got mine in the garage after being pizzed about with the wheels that I was buying.
11th Mar 2020 8:40pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7682 |
What sort of money are people getting km3 255.85s for? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Mar 2020 9:37pm |
Cheapest I could find them for was £157 each from Camskill, ordered them Sunday and saw on Monday they had gone up to £171 each!
11th Mar 2020 10:26pm |
