Home > Off Topic > Anyone good at DIY car body painting?
Page 3 of 4 <1234>
grafty99
Might be worth buying another can Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #818187 4th Mar 2020 9:16pm
Bluest
Really struggling to get the bodyline right. It had sustained a supermarket trolly dent right on the line which I thought would be easy to fix, but not having much luck reinstating a straight line if the right radius.
 2007 110 TDCi Station Wagon XS
Post #819759 15th Mar 2020 4:56pm
grafty99
A long block with a radius is the way forward. About 400mm long ish Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #819764 15th Mar 2020 6:44pm
Clemmo
I’ve spray painted a few cars...
It’s always easier to spray a vertical panel than a horizontal one... get it vertical if you can. Maybe hang from something?
Dust is always a major problem so invest in a few “tac rags’ as a final wipe over before paint.
Also water the floor where you are working...it’s amazing how much dust you kick up.
Only paint when it’s dry and not humid otherwise you will get a bloom effect and possible micro blistering later
Thumbs Up Clemmo
Post #819766 15th Mar 2020 7:06pm
Bluest
Thanks Grafty, I guess I can make a block out of a length of wood and then attach the abrasive with double sided tape? 2007 110 TDCi Station Wagon XS
Post #819773 15th Mar 2020 8:03pm
Bluest
Thumbs Up Clemmo
Slightly ahead of you, I did have a problem with dust when I sprayed it flat last time, so I;ve rigged a way to gang it from the ceiling for future painting. Thumbs Up
I've got no tac rag, but I do have a ton of panel wipe and some lint free cloths. 2007 110 TDCi Station Wagon XS
Post #819774 15th Mar 2020 8:05pm
grafty99
Yeah that'll do it, just make sure it's smooth. Any lumps will transfer into the filler Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #819778 15th Mar 2020 8:37pm
Grenadier
Quick question to all the knowledgable types. As mentioned already, I'm thinking of doing this this summer. The whole DC exterior. I'm happy to take my time, panel by panel, door by door. I'm doing it because my paint looks dull, and in parts is peeling/bubbling. I am not doing it to also affect an repairs on dents. With this in mind, and baring in mind that I don't have any large or noticeable dents, do I need to fill them anyway? Will simply painting the areas create a weak spot in the paint because of the dent? Note that I fully intend to do the full layers, primer, coats, etc, just wondering if I need to add the extra labour for what are a very few small dents? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #819831 16th Mar 2020 7:55am
grafty99
Preparation is key - pun intended Laughing
As long as the paint is properly keyed, all the way into the dent then it will have no effect on the paint. Although if you're going to paint the defender then it's the perfect time to sort the dents Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #819839 16th Mar 2020 9:15am
Bluest
I’ve gone again with the etch primer and much happier this time. The finish is very slightly orange peel which might come out with some 1200 wet and dry. I think that happened because I had too small a nozzle on the gun (1.4) and not enough volume of paint getting through.
Post #820411 20th Mar 2020 8:38pm
Grenadier
I’m in enforced quarantine. Loooooads of time on my hands (I left work as I’m about to PM the renovation of my farmhouse....great timing Shocked ) and I can’t get the parts I need to do any work on the Def. Would have been a perfect time to start stripping the panels. Ho hum. Only another ten days to go. Big Cry Monsieur Le Grenadier
Post #820468 21st Mar 2020 8:43am
grafty99
Looking good Thumbs Up
I'm hoping we don't have to close our 'site. Luckily I've been planning for lock down and got some parts in stock, just in case Shocked 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #820473 21st Mar 2020 9:07am
Bluest
I’ll run out of materials to continue this job today. I’m hoping I’ll still be able to web order stuff next week. 2007 110 TDCi Station Wagon XS
Post #820474 21st Mar 2020 9:11am
Bluest
Well, the jobs stopped indefinitely by Corvid 19. I can't get replacement filters for my respirator, everywhere is either out of stock or only supplying health care. I'll need to find something else to do to pass the time 2007 110 TDCi Station Wagon XS
Post #820850 23rd Mar 2020 5:04pm
Grenadier
^^^ PornHub is ‘apparently’ (clearly I’ve not checked) offering free subscription.... Whistle Rolling with laughter Monsieur Le Grenadier
Post #820851 23rd Mar 2020 5:17pm
Page 3 of 4 <1234>
