Home > Technical > Mt82 de Puma a 300 TDI
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Dear, is there a kit to adapt mt82 box to TDI engine?
Regards
Post #818136 4th Mar 2020 3:40pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
There's https://www.mdengineering.co.uk/shop/adapt...2-gearbox/ but it's not cheap! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #818139 4th Mar 2020 4:04pm
Fernando
Many thanks Thumbs Up
Post #818146 4th Mar 2020 5:29pm
o4dn
It's just the adaptor though, depending on what you plan to do there might be more to it than just mating the gearbox to the engine.
I would also expect additional changes to be required in the mountings on the chassis, the bulkhead and the gearbox tunnel as well, as those also differ from a 300TDi, I reckon.
The gear stick and differ lever also differ on a Puma Defender. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #818147 4th Mar 2020 5:38pm
o4dn
However, from the page I linked:
Quote:
When this kit is fitted with the MT82 instead of the R380 in a 300 Tdi Defender the transfer box is 55mm further back than the 300Tdi installation. This puts the transfer box in the same position as the Tdci Defender. An optional mounting kit is available to mount the MT82 gearbox on the standard 300tdi gearbox chassis brackets
So maybe that's enough... I'd be curious to know how that'd go, keep us posted! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #818148 4th Mar 2020 5:42pm
Fernando
Yes, I am evaluating the change only for the very slow first speed.
Post #818152 4th Mar 2020 5:59pm
DSC-off
Hi, that kit will adapt the engine to the MT82 gearbox, but what is the arrangement to connect the gearbox to the transfer box?
The kit does not show any parts to do that, so I would assume you will also need the puma adapter housing and intermediate shaft.
If this is indeed the case, then use the upgraded Ashcroft shaft kit.
There are many threads on this forum about the failure of standard shaft between the puma gearbox and transfer box. Sometimes at very low miles.
https://www.defender2.net/forum/topic62521...;start=120
Post #818176 4th Mar 2020 8:13pm
DSC-off
From the MD description,
"When this kit is fitted with the MT82 instead of the R380 in a 300 Tdi Defender the transfer box is 55mm further back than the 300Tdi installation. This puts the transfer box in the same position as the Tdci Defender. An optional mounting kit is available to mount the MT82 gearbox on the standard 300tdi gearbox chassis brackets"
So that will require Puma prop shafts too, due to the change of length.
It's starting to sound like you would need a complete puma transmission between the clutch and the axles.
Post #818196 4th Mar 2020 9:44pm
I wonder what the gearing would be like with an MT82, original 1.4 ratio LT230, and a TDi engine. Low first would be exceptionally low, I'd think.
Post #818202 4th Mar 2020 10:04pm
jst
And potentially unusable, similar to tdci hence idle jack Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818237 5th Mar 2020 8:18am
Fernando
That is exactly what I want!
The Defender is used for exploration on the mountain where there is no road and only large stone is found.
regards
Post #818246 5th Mar 2020 9:44am
o4dn
And 1st gear in low range is not sufficient for that? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #818247 5th Mar 2020 9:47am
o4dn
Oh, I just realized your profile shows you have a Puma already, does it mean you want to keep all the transmission from the Puma and replace the engine with a 300TDi? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #818248 5th Mar 2020 9:49am
Fernando
My adventure partner has the Defender 110 TDI year 1998 !!!
I, very happy with my Puma 2.4 with 300 thousand km!
Post #818252 5th Mar 2020 10:17am
jst
An underdrive? Same price as the adaptor plate. Struggle will be finding one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818271 5th Mar 2020 12:53pm
