Home > Td5 > TD5 Def oil filter...
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
This might be an odd post but...
Im always reading about TD5 owners hating doing oil changes because its so difficult to get to the main oil filter...
Im really confused because after putting it off, I drained my engine, took off the centrifuge/rotor housing, swapped that out in a minute or two. And then moved onto the main filter, could barely see it from underneath the car where I thought it would be coming out from. So popped up top, realised it was right by the turbo. Got 1 hand behind the turbo and one in from the left near the centrifuge and just unwound it. A little tight but could get both hands on it so it just came out easy. A little drip from angling it to remove it. Cleaned up, lubed seal on new filter and put it straight on the thread, wound it on nice and tight, job done.
I'm wondering what is normally tripping people up?!
Post #817975 3rd Mar 2020 12:39pm
bankz5152
People often over tighten them. Making a 5 min job take potentially hours. Happened to me first time I serviced my 110, never happened since.
Post #817988 3rd Mar 2020 1:32pm
rallysteve
i use one of the filter spanners, makes doing it up and removing it dead easy (as long as you have a genuine or OE shape filter) especially when the engine is still warm.
Post #818004 3rd Mar 2020 2:17pm
jst
They are fine to do as long as they arent over tightened by previous installer! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #818060 3rd Mar 2020 10:22pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I do mine up hand tight and I can normally undo it with my hands too. Even when I got the vehicle the previous owner must have done the same as I managed to undo it with my hands.
Post #818070 3rd Mar 2020 11:50pm
benniferj
That makes more sense, thanks for the clarity, I guess as long as it's been serviced and tightened properly rather than brutally, it should be fine, otherwise a little awkward.
That said it's not hard to drop the downpipe which I guess would make it pretty easy to rectify. Im just happy to have an easy job for a change!
Someone mentioned the oil filter tool, I forgot that id ordered a td5 one and have it in the toolbox just in case Confused
Post #818082 4th Mar 2020 9:00am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Following your post benniferj I popped out and tried to get both hands on it which I managed Shocked
So when its next due ill try this first.
Post #818144 4th Mar 2020 5:03pm
roel
I don't really think that the problem is how tight it is but more how much off a mess it can become. I normally thighted it by hand but need my tool to get it loose,
But as soon as I "broke"it loose I put a small plastic bag around the filter to catch the oil that come out. I like to change the oil when the oil is nice and warm. Roel
2003 90 Td5 (2009-now)
Post #818157 4th Mar 2020 6:46pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
What I do also, is put a plastic bag under /on the filter when undoing it , that way when it’s unscrewed and tipped to remove it from the car it doesn’t drop oil everywhere, as the bag catches it,
I also use filters that I can use the correct oil filter spanner on ( mine was from twisted but I’m guessing many make them now,
Thumbs Up
Post #818165 4th Mar 2020 7:50pm
V8GPC
Love the bag tip.. I've never managed to remove a filter yet from my V8 without pouring ALL the oil down my arm
Post #818195 4th Mar 2020 9:39pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I do mine by hand. I did have a issue once with a man filter that was slightly longer than the rest I've had. It was hard to get in position and start on the threads.
That was a one off though 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #818307 5th Mar 2020 5:15pm
lightning
The genuine Land Rover oil filter has a non return valve in it, and hardly any oil leaks out when you remove it.
Other oil filters l’ve used make a right mess as half the oil pours out when you tip the filter sideways to get it out from under the turbo.
Post #818572 7th Mar 2020 12:07am
