Home > Wheels & Tyres > 315/70/16 MTs Any issues? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7681 |
I have always updated shafts and cvs for off roading with 35s. Open diffs included. A 35 finding grip is a big turning moment.
Guess it depends if you want reliability when off tarmac. Vehicle is lifted to avoid fouling on bump lock I take it? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
1st Mar 2020 10:36pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2057 |
Yeah do need it relaible on tarmac as I would be doing some long journeys fairly often. That much of an issue on Tarmac?
Best sticking with a more aggressive 33? Instagram @defender_ventures Empire Tuning - Agent |
1st Mar 2020 11:17pm |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 |
Run 35 creep crawlers on my off-roader which also has standard shafts and cvs. Only time I’ve broken one is when “playing” on rocks and using left foot braking.
It is an auto which helps a lot with the forces. For road use you will be fine, it is the snatch loading that will cause things to break. Hold my beer and watch this! |
2nd Mar 2020 7:22am |
35s on the torque multiplier of a tdci gbox 1st gear is not something i would be doing if i wanted reliability. thats before engine upgrades and adding ATBs etc. on or off road. i assume more off road from tyre patterns suggested. Cheers
2nd Mar 2020 11:20am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3316 |
Been running 35s (bfg ko2)for nearly 3 years now on 2015 puma. Mix on and off road, no issues to date with standard diffs and +2inch suspension
2nd Mar 2020 12:00pm |
