![]() | Home > Wheels & Tyres > 315/70/16 MTs Any issues? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
I have always updated shafts and cvs for off roading with 35s. Open diffs included. A 35 finding grip is a big turning moment.
Guess it depends if you want reliability when off tarmac. Vehicle is lifted to avoid fouling on bump lock I take it? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Yeah do need it relaible on tarmac as I would be doing some long journeys fairly often. That much of an issue on Tarmac?
Best sticking with a more aggressive 33? |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Run 35 creep crawlers on my off-roader which also has standard shafts and cvs. Only time I’ve broken one is when “playing” on rocks and using left foot braking.
It is an auto which helps a lot with the forces. For road use you will be fine, it is the snatch loading that will cause things to break. Hold my beer and watch this! |
35s on the torque multiplier of a tdci gbox 1st gear is not something i would be doing if i wanted reliability. thats before engine upgrades and adding ATBs etc. on or off road. i assume more off road from tyre patterns suggested. Cheers
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3416 ![]() ![]() |
Been running 35s (bfg ko2)for nearly 3 years now on 2015 puma. Mix on and off road, no issues to date with standard diffs and +2inch suspension
