Home > Maintenance & Modifications > Head unit won't fit
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Head unit won't fit
Apologies if this has been done to death in the past, I've done a search but couldn't find anything.
Got a new Pioneer head unit today, took the LR one out, plugged the new one in, tested it before mounting it, all works fine... All within about 10 minutes. Was surprised how easy it all was,
BUT...
Coming to actually fit it... Censored !
The 'cage' won't fit in the dashboard, it's a millimeter or two too wide it seems. Take the cage off and the stereo won't fit securely. The Land Rover stereo had a screw with a rubber type bung round at the back, which locks into a metal bar behind the dash, but this won't fit on the Pioneer head unit... So, am I missing something completely obvious here??
Just thought I'd ask to see if anyone else has had any issues before I take it to halfrauds or wherever tomorrow.
Post #81688 23rd Jul 2011 7:52pm
Lorryman100
Remove the centre panel and you will see there are two metal spacers fitted to either side of the radio aperture hole. These need to be removed with a screwdriver to allow the new radio cage to be fitted. I found it easier to mount the radio by first fitting it into the centre panel and then refitting the panel complete as this gives you a chance to route the radios cables clear of the rear metal bracket when refitting.
Post #81692 23rd Jul 2011 8:02pm
warren
Thumbs Up Thumbs Up
I noticed them and wondered if they came off, didn't look like they did though.
Thats tomorrows job sorted anyways Smile
Cheers Thumbs Up
Post #81694 23rd Jul 2011 8:09pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
hi
had this trouble with mine .managed to remove the metal clips without removing the whole centre
get a small bladed screwdriver in right at the bottom and pull towards the centre of radio hole.
slow and steady pressure as these are fitted as non return push fit. but them do come off.
the second one will be easier as you then know how hard you need to prise.
good luck Thumbs Up 110 xs s/wagon
s3 swb soft top
Post #81735 23rd Jul 2011 10:52pm
spudfan
Ireland
"Head unit won't fit."
Should this not be in the "adult" section of the Off Topic section?
Or is he just trying to make the rest of us jealous? Rolling with laughter 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #81742 24th Jul 2011 12:20am
warren
Rolling with laughter I was having a laugh at that thread last night before it got deleted. Quality!
Managed to get the spacers off without taking the centre console out. Managed to catch the first one, but the second one flew off behind the dash somewhere Rolling Eyes
Slipped right in (oo err), and impressed with how much better it sounds even with the standard speakers! Still sounds crap, just a little bit less crap.
Thumbs Up
Post #81770 24th Jul 2011 12:12pm
