![]() | Home > Td5 > front grille surround panel removal |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
It must have been put together somehow, so it must come apart! It does look a bit of a puzzle though.
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
The grille I’ve got came with instructions that said to assemble the grille and panel and then fit the panel to the vehicle. Very easy with an aircon panel. Bit of a faff if not. I’m 95%, if not 100%, certain you’ve got to come at those bottom two bolts from the underside. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Remove the engine and go in from the back? Darren
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Bit extreme measure to take the grill off
![]() As a similar could you not remove rad/ intercooler IIRC bolts for this are accessible from engine bay |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 ![]() ![]() |
Might have to just take the engine out next weekend. Shouldn’t take too long
![]() Yes I’ll remove the steering guard Baron and see if I can get at the from below. Thanks for the replies! I’ll keep you guys updated. Instagram - @Land_Rover_Defender |
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 ![]() ![]() ![]() |
I’ve just fitted this grille to my non aircon model so have just done the reverse of what you are trying to do. Yeah they are accessed from underneath, I used a ratchet with plenty of long reach attachments and stepped down to be the narrowest socket set I own with an angled UJ socket piece on the end (or whatever they are called) and you should be able to get to those bottom bolts. When I fitted the grille I had to cut a slot in the side of the grille so I suspect yours will be the same and you just need to undo the bolts about 5mm and the grille should slide out.
One of these with a long extension bar... ![]() Click image to enlarge |
Thanks sgreenham. I will give that a go at the weekend. Cheers. Instagram - @Land_Rover_Defender
Well this grille is a stupid design. Can't access the bolts from the bottom and because I can't get the grille out I can't get to the bolts which would let me remove the grille fascia panel. Not a clue how this has been fitted, unless is was done with the intercooler removed but that is so much work to just remove a grille? Instagram - @Land_Rover_Defender
Surely it cannot be that complicated to get the panel off? Do you know the grille manufacturer? You might be able to get fitting instructions for it and then reverse them. Charlie
This grille is not designed to be fitted to a 'non aircon' front, it has almost certainly been glued / siliconed in place - you will need to lever it off ....
Here are the installation instructions: https://www.zunsport.com/en/landrover-defender-full-grille-set |
No update. The grille is still on. Yes I don't understand why it is so difficult Baron
![]() In response to it being glued on. The bolts have actually been bolted down with the nuts. So if it had been siliconed into place then there is no way you would be able to put the nuts on after this. Meaning it must have been bolted on. My only thought now is to remove the slam panel and undo the four bolts at the top. Leaving the two bolts at the bottom to get at, which I can't however because the grille is in position. I literally just want to remove the grille to clean the intercooler and paint the braces... Instagram - @Land_Rover_Defender |
And you’ve tried removing the steering guard to gain access? Charlie
Got the b*****d off! So I removed it by getting a ratchet spanner onto the bolts on the side from the engine bay. It was a very tight squeeze, thankfully I have smaller hands else it would have been difficult. So anyone with the same grille and non AC then that is the way to do it.
I have removed the slam panel to paint it tidy it all up. Thanks for the help with it! ![]() Click image to enlarge Instagram - @Land_Rover_Defender |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Great news
![]() 2008 SVX 90 2000 XS TD5 90 |
