Home > Td5 > front grille surround panel removal
Page 2 of 3 <123>
Greeny
Haha no they won’t be red don’t worry Greeni!
From my understanding you need to remove the grille in order to get to the 4 bolts at the top and the 2 at the bottom. My issue is that I can’t remove the grille. I can’t access the bolts that hold the grille in place. The pictures I have taken show where the grille is attached to the surround. I might be able to access them from the bottom but I’m not sure yet Instagram - @Land_Rover_Defender
Post #816890 25th Feb 2020 4:45pm
It must have been put together somehow, so it must come apart! It does look a bit of a puzzle though.
Post #816911 25th Feb 2020 7:12pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 SW Santorini Black
The grille I’ve got came with instructions that said to assemble the grille and panel and then fit the panel to the vehicle. Very easy with an aircon panel. Bit of a faff if not. I’m 95%, if not 100%, certain you’ve got to come at those bottom two bolts from the underside. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #816913 25th Feb 2020 7:16pm
Remove the engine and go in from the back? Darren
Post #816914 25th Feb 2020 7:16pm
htb2
Bit extreme measure to take the grill off Very Happy
As a similar could you not remove rad/ intercooler IIRC bolts for this are accessible from engine bay
Post #816924 25th Feb 2020 8:05pm
Greeny
Might have to just take the engine out next weekend. Shouldn’t take too long Laughing
Yes I’ll remove the steering guard Baron and see if I can get at the from below. Thanks for the replies! I’ll keep you guys updated. Instagram - @Land_Rover_Defender
Post #816958 25th Feb 2020 10:20pm
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
I’ve just fitted this grille to my non aircon model so have just done the reverse of what you are trying to do. Yeah they are accessed from underneath, I used a ratchet with plenty of long reach attachments and stepped down to be the narrowest socket set I own with an angled UJ socket piece on the end (or whatever they are called) and you should be able to get to those bottom bolts. When I fitted the grille I had to cut a slot in the side of the grille so I suspect yours will be the same and you just need to undo the bolts about 5mm and the grille should slide out.
One of these with a long extension bar...
Post #816991 26th Feb 2020 5:42am
Greeny
Thanks sgreenham. I will give that a go at the weekend. Cheers. Instagram - @Land_Rover_Defender
Post #817103 26th Feb 2020 8:36pm
Greeny
Well this grille is a stupid design. Can't access the bolts from the bottom and because I can't get the grille out I can't get to the bolts which would let me remove the grille fascia panel. Not a clue how this has been fitted, unless is was done with the intercooler removed but that is so much work to just remove a grille? Instagram - @Land_Rover_Defender
Post #817701 1st Mar 2020 12:40pm
BaronDefenders
Surely it cannot be that complicated to get the panel off? Do you know the grille manufacturer? You might be able to get fitting instructions for it and then reverse them. Charlie
2002 Td5 90 (SOLD)
Post #817702 1st Mar 2020 12:43pm
This grille is not designed to be fitted to a 'non aircon' front, it has almost certainly been glued / siliconed in place - you will need to lever it off ....
Here are the installation instructions: https://www.zunsport.com/en/landrover-defender-full-grille-set
Post #817899 2nd Mar 2020 2:42pm
Greeny
No update. The grille is still on. Yes I don't understand why it is so difficult Baron Rolling with laughter it is really annoying haha.
In response to it being glued on. The bolts have actually been bolted down with the nuts. So if it had been siliconed into place then there is no way you would be able to put the nuts on after this. Meaning it must have been bolted on.
My only thought now is to remove the slam panel and undo the four bolts at the top. Leaving the two bolts at the bottom to get at, which I can't however because the grille is in position. I literally just want to remove the grille to clean the intercooler and paint the braces... Instagram - @Land_Rover_Defender
Post #818218 4th Mar 2020 10:36pm
BaronDefenders
And you’ve tried removing the steering guard to gain access? Charlie
2002 Td5 90 (SOLD)
Post #818220 4th Mar 2020 10:42pm
Greeny
Got the b*****d off! So I removed it by getting a ratchet spanner onto the bolts on the side from the engine bay. It was a very tight squeeze, thankfully I have smaller hands else it would have been difficult. So anyone with the same grille and non AC then that is the way to do it.
I have removed the slam panel to paint it tidy it all up. Thanks for the help with it!
Post #818811 8th Mar 2020 6:39pm
Sulisuli
Great news Thumbs Up who would imagine it could be that difficult. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #818815 8th Mar 2020 6:52pm
Page 2 of 3 <123>
