Home > My Defender > My 110 MILLIE.
Page 33 of 70 <123 ... 323334 ... 686970>
Sulisuli
Great work Clayton Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #813813 5th Feb 2020 8:41pm
L110CDL
Thanks Simon Thumbs Up Clayton.
Keeper.
Post #813816 5th Feb 2020 8:47pm
Top job there, and a little upgrade as well at the same time. Wink
Was there much wear on the original door catches? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #813818 5th Feb 2020 8:51pm
Those X Trouser catches are great. Very nicely made and do seem to work as intended. Darren
Post #813829 5th Feb 2020 9:17pm
I must try and get a pair of those one day, good to hear they are popular.
I've caught myself in the factory ones many times like others have. ____\We|Will|Win/___
Post #813832 5th Feb 2020 9:21pm
L110CDL
The old ones had worn allot and only time will tell if i catch my trousers on these ones Wink Clayton.
Keeper.
Post #813835 5th Feb 2020 9:27pm
L110CDL
Well, this Saturday just gone, Millie went in for another one of her 6,000 miles services Very Happy
All ok and went well, got the new disc's and pads on the back and feeling much better now Thumbs Up
As i heard a knocking sound which i thought might be the shocks, so i asked my indy to have a look and it turns out that one of the bushes on the " A " frame has gone so they will get changed this coming Saturday Very Happy
At the same time she was in, she had a little present/upgrade/tidy up . . . .
Before
After
Much better Thumbs Up Clayton.
Keeper.
Post #814673 11th Feb 2020 8:15pm
Sulisuli
You washed all the colour off the hoses Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #814675 11th Feb 2020 8:36pm
L110CDL
Laughing
Been wanting to get that job done for a while, all done and i'm well chuffed Very Happy Clayton.
Keeper.
Post #814678 11th Feb 2020 8:47pm
Procta
L110CDL wrote:
So about a couple of weeks ago on the way home from picking up the wife from work, i had this type of squeaky noise that i had not heard before, so i tried to find it and pinned it down to the drivers door, so before i had a chance to have a good look at it, the problem was found by catching my jumper sleeve on the bit of plastic that goes around the thing you lock and unlock the door with was loose Rolling Eyes Very Happy
The weekend just gone i made a start on taking the door card off and with it all exposed i saw the problem, the plastic bit had totally broken .....
At the same time i set about fixing the well known week spot on the door as i did try to fix this a few years ago but to no avail Rolling Eyes
I started of with the bolt that secures the window mechanism as a good point then i got a good piece of metal and filed the cut edges smooth, then drilled a hole for the bolt to go through, then bent it to the right angle and then drilled the other hole in the door ....
Then the piece of metal in place and a nut and bolt on the right hand side ...
With this done the door was back to normal, no flex in it and nice and firm, i always keep plenty of stock for breakages and so with the new part in ....
Then just to put the door card back on ......
What a difference the piece of metal has made, the door shuts spot on with a good solid sound and i'm well happy with the outcome Very Happy
Has it split there? If has you can get some eproxi resin stuff that you use to bond panels to gether with. That will sort that out . Me and my dad used it on his battery box and rivited the thing together. Solid as a rock now! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #815727 18th Feb 2020 1:38am
Procta
Before
After
you missed a bit Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #815728 18th Feb 2020 1:38am
L110CDL
Depends which " bit " you are referring to Whistle Clayton.
Keeper.
Post #815907 18th Feb 2020 10:22pm
Procta
you need a alisport swirl pot for the breather Thumbs Up also I would paint the green bits black Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #816365 22nd Feb 2020 12:39am
L110CDL
All in good time Procta Whistle
The green is staying as most of what you can't see is green on Millie Wink Clayton.
Keeper.
Post #817465 28th Feb 2020 10:04pm
Procta
well at least get grafty to white letter his tyres Very Happy Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #817480 28th Feb 2020 11:49pm
