![]() | Home > My Defender > My 110 MILLIE. |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
All good for this saturdays fun then
2008 SVX 90 2000 XS TD5 90 |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Yep
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I didn’t like to mention the draughtiness on Saturday
No worries there Simon, glad you enjoyed it 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2309
Cant believe you 'broke it'.......... |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
So first of all we had tip polishing, yes I joined the club about a week ago.
Now we've had draughty flaps. On a different note. Was it that adhesive double sided type tape that LR originally used on the seals? If so, that's terrible stuff as it goes soft when it gets warmer weather and will just push ofo or slip off. I've had some foam tape with that type of adhesive on and it's pretty useless, so much so there isn't any point in using it. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
The first time it went was between the foam and rubber , really strange that, then this time is was the tape that sticks it to the flap 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I've known the foam to go, it's self but not the adhesive as well. I try and avoid foam tapes now where possible for that reason.
It can be very annoying I know. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 29th Oct 2019 10:38pm. Edited 1 time in total |
Yes it's very very annoying, it's ok in the summer months but you tend to notice it a bit more this time of year
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5376
You cannot beat industrial glue at all, I repaired my 306s seat recliner handle with that stuff. Also my defenders steering wheel too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Yes it is Procta
Millie has been going great but the other day when i had got to my work store and stopped her to load up, she smelt very diesely, this was the 3rd or 4th day like this so i lifted the bonnet and found the the front injector all wet with diesel
So about a couple of weeks ago on the way home from picking up the wife from work, i had this type of squeaky noise that i had not heard before, so i tried to find it and pinned it down to the drivers door, so before i had a chance to have a good look at it, the problem was found by catching my jumper sleeve on the bit of plastic that goes around the thing you lock and unlock the door with was loose
The weekend just gone i made a start on taking the door card off and with it all exposed i saw the problem, the plastic bit had totally broken ..... Click image to enlarge At the same time i set about fixing the well known week spot on the door as i did try to fix this a few years ago but to no avail I started of with the bolt that secures the window mechanism as a good point then i got a good piece of metal and filed the cut edges smooth, then drilled a hole for the bolt to go through, then bent it to the right angle and then drilled the other hole in the door .... Click image to enlarge Click image to enlarge Then the piece of metal in place and a nut and bolt on the right hand side ... Click image to enlarge With this done the door was back to normal, no flex in it and nice and firm, i always keep plenty of stock for breakages and so with the new part in .... Click image to enlarge Then just to put the door card back on ...... Click image to enlarge What a difference the piece of metal has made, the door shuts spot on with a good solid sound and i'm well happy with the outcome 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
So after fixing the door lock and door, i set about changing over the door catches as those are the original ones to these ...
Click image to enlarge The old ones that came off .... Click image to enlarge So with those fitted i set about sorting the doors out, first was making sure the lines were all lined up and then sorting the new door seal gaps I had been thinking about this problem for a week or two and having a good look, i came up with a plan of action and i have now sorted both doors now so they don't leak and waver in and out when on the move, well chuffed with the out come 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
| All times are GMT |
