![]() | Home > Off Topic > Robotic Lawn Mowers |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 210 ![]() |
We've had a Husqvarna 330X for about 6 years now.
It's been absolutely brilliant - once you get it set up you really can just leave it to do it's thing and not have to worry about mowing the lawn ever again ![]() Only con is that it doesn't mow right up to the edge, so every now and then you need to strim the very edges of the lawn, but depending on how your lawn is laid out you may not have to do this... |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Best on market and will free up more time than you think
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1637 ![]() ![]() ![]() |
Hi I’ve just popped out and looked as I knew it was a Husqvarna but wasn’t sure of Model, no issues to mind keeps the part of the lawn it does beautifully short and as mentioned it mulches took a while to get used to the headlight though as it mows overnight very clever bit of kit in my opinion and as mentioned once set up you can forget it
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Setting it off in the daytime and watching it trundle round is remarkably relaxing as well, especially with a cold beer ![]() |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
Thanks for your responses, all of which are very positive. I've already had a quote from our local Husqvarna dealer so I'll be placing my order tomorrow.
![]() I like Jonny's idea of sitting back and watching it whilst downing a cold beer or two ![]() Mini Countryman Cooper S Morgan Plus 8 |
When we first got ours we had someone out to install it, we've since moved house and I installed it in the new place myself - it's not at all complicated...
If they want a lot of cash to install it then I'd seriously consider DIY ![]() Also - depending on your lawn size, some other makes are Husqvarna's rebranded - eg. Flymo and can be considerably cheaper. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
What kind of range does it have? (Honestly a serious question)
I looked at them a while ago because I have a rather large lawn (about 4 acres ![]() ![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Sako I think you need a flock of sheep, not a robotic mower, then when they start to loose their efficiency you can even eat them......... unlike a battery powered mower. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Had some over the winter - problem is the grass is so good they get the trots and leave smelly green stuff everywhere.
Then one sod got out when I took the dogs out in the morning. After spending an hour in my dressing gown trying to get the sod back in I gave up and phoned up Mum asking permission to terminate it with the .243 and the quick response was Dad's on the way to bring them back to the farm ![]() It's not too bad on the ride-on now I've got both blades at the same height - only takes a morning or so. Lawn looks much nicer than with lamb on it. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Hmm 🤔 4 acres, I can’t help with the range however what I can say is the 450X is suitable for up to 5000M2 (1.25 acres) and self docks when it requires charging as mentioned never had any issues with this one but also have a small garden tractor and walk behind for the other garden areas, but I’m sure if you speak to one of the dealers they will answer your question re the size of lawn you require being mown👍 hopefully they will be able to help
Yeah but >£1k for a lawn mower buys a lot of petrol
Yes but you get a lot of mornings or so back with less stress too. Also remembering to take the fuel can with you to get some fuel
