Home > Puma (Tdci) > Optimum Comfort/Handling Puma 110 Tyre Pressures? |
I'm guessing your 'standard commercial' is the utility station wagon shown in your profile? If so, it will definitely have different rear springs to a passenger station wagon. The latter uses dual rate springs and I have a set in my garage ready to fit to my USW when the weather warms up a bit! Whilst superficially similar, the USW is quite different from a regular SW. Not only do they have heavier rear suspension to cope with 'commercial' loads, but the base vehicle is lighter as it doesn't have the rear seats and glass of the latter. Consequently, if you typically run near empty, the ride can be comparatively rather harsh. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Feb 2020 9:00am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
Does the USW have the same 1 tonne payload that the double-cab has?
14th Feb 2020 12:46pm |
I believe so, yes. Darren
14th Feb 2020 3:06pm |
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 |
Ok - and does anyone know what would be a good set up at a sensible price? |
14th Feb 2020 5:59pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I'm not sure you can call £650 cheap, but I'd be looking at something like this. Or speak to the likes of Gwyn Lewis for a custom package. 2007 110 TDCi Station Wagon XS
14th Feb 2020 6:04pm |
Yes this one is a USW Ok - this is concerning as had I realised this I would have made certain that I only looked at buying the Station Wagon. I intend to put the insulation down on the floor from the back of the front seats right through the rear footwell, under the 2nd row of seats and into the entire rear area. And then put carpet on top which I did on my last one which made quite a difference to the sound insulation- but I’d like to know what changes I need to make to the rear suspension to get it more in line with the Station Wagon. |
14th Feb 2020 6:06pm |
There are lots of options, depending how far you want to go. Some folks on here have fitted 'comfort' springs from Alive Tuning and are happy with the results, although they're not cheap and do lower the vehicle height. Personally, as I said above I'm going to try a set of passenger station wagon springs, which is a relatively low cost option, and see how they feel. I'm not that put out by the existing ride though, if I'm honest, so I'm experimenting as much out of curiosity as anything.
I have fitted sound insulation and carpet to the rear, which has made a huge difference to the noise levels. As standard, it's like driving around inside a drum. You can see details of my approach to this here: https://www.defender2.net/forum/post711655.html#711655 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Feb 2020 9:26pm |
Ok so I’ve enquired at Alive Tuning about getting the softer springs and having a stage 1 Remap done at the same time. I’ve also bought the Dynamat sound insulation package to do the entire interior of the vehicle (apart from roof and doors) and a carpet set from the front footwell back. Booked a friend to help me fit all the insulation and carpet over a weekend once it arrives.
Once I’ve done all this insulation to the floor, is there really any requirement to do the roof and doors as well do you think or not really? I’ve already got the insulating side panels in the back as you can see in this photo. Click image to enlarge |
16th Feb 2020 1:36pm |
16th Feb 2020 1:37pm |
I'd definitely recommend doing the roof. I've done both a 90 and a 110 and the difference is significant. The doors are nice when done, too, but they're a lot more work to strip down and so the benefit/effort equation is a bit more marginal.
Click image to enlarge Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
16th Feb 2020 9:02pm |
Ok I’m definitely going to insulate the roof.
Alive have a new suspension upgrade to soften the suspension with new springs and shocks without lowering the ride hight so I’ve booked it in for these And the stage 1 Remap. Also bought the leather XS cubby box with padded top to match the Premium seats and matching white stitched leather grab handle, dash top and Binnacle top! The black external changes will have to wait now |
17th Feb 2020 7:00pm |
