![]() | Home > Td5 > TD5 wont start |
| davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110
Hi these 3 fuses in particular where are they cant see them under the seat or under the dash
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Fuse td5 02 to 06
https://www.lrworkshop.com/electrics/defen...nd-headers |
thank you
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
On mine, might be different on yours, F21 is the hazard fuse but also the AS10. Can be overlooked. Peter
as a final follow up
had the ecu tested by ecu testing, then repaired £324 and the truck is as good as new with a life time warranty on the ECU |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Did they say what was up with the ECU? 1999 Defender TD5 110
No They didnt, did ask but got no reply
guess they like to keep the knowledge hidden and I would too |
does a disco nnn works okay on a defender as is subject to injector values ?
| LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886
Works fine, just typed in the injector codes in the nanocom and put a defender fuel map in it and it seems fine
| All times are GMT |
