![]() | Home > Maintenance & Modifications > 2012 SW utility 110 interior replacement trim? |
| oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741
http://www.wrightoffroad.com/products.htm It is not a Defender, it is a One_Ten
| sconie Member Since: 10 Jan 2020 Location: Paisley Posts: 50
Thanks for that π, I'll call them. Hopefully not too pricey. Cheers
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
I was going to suggest the Wright matting earlier, but I don't think they do them for any gearboxes beyond the R380, and I think they're a bit spendy.
That said, I've got a set myself, have had for years and years. I got it at a good price off ebay about 10 or more years ago. The stuff really is bomb proof. I've not long bought a couple of the flat sheets and cut them up to fit in the back, on the strength of how good the front mats are. If you can get a set for your car, and you can find the cash, you'd never need anything else. I'd think the easiest other option would be to keep an eye out for a straight replacement for the standard stuff you have. I think it's got a thin foam back from memory, glued onto the seat box. You might be able to pick up some self-adhesive closed cell foam which you could them cover with the outer skin of the standard ones. More likely you'll find carpet 2nd hand, which might do too? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks for the reply. I have seen a few online tonight, not sure if they are puma 2012 or not though? If it comes to it I'll strip off the current one, make a template and find a suitable material and look that suits and make my own.
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Is this any good to you?
https://www.defender2.net/forum/topic70946.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks Darren, it's the corners on my original that have gone too, what's the damage like and what would I repair it with? If its in better shape than mine I'd be happy to make a contribution.
Cheers |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21045
You may find a corner protector might hide some of the wear. (It depends on if the protector is wide enough to cover it?
The Seatbox corners are a common wear point, mine has had the exact same thing happen. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks yet again.... You wouldn't have a source for such an item? Might be a big saving. Cheers
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895
Hi sconie
The bits on offer are mine. They were from a 2015 puma with 20,000 miles and apart from needing a corner protector Β£15 are in mint condition. Only removed them as i removed the interior to replace with carpet. Protectors are Β£15 a side Click image to enlarge |
Hopefully in better condition than mine then, I'm up in Glasgow so would need a courier type delivery, if you can let me know the postage cost id be happy to contribute a donation then repair.
Cheers Sconie |
Take a look at Mud UK, these are the ones I have. You may find there are others out there that are a bit bigger and might cover more of the area. Even if they don't it would look better. Sourcing these mats isn't easy, mine is tatty too and worn even though it hasn't had much actual wear. Usually on corners. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| All times are GMT |
