Home > Maintenance & Modifications > 2012 SW utility 110 interior replacement trim?
sconie
Hi all, my 110 station wagon which i
Has a utility finish inside is showing signs of wear and tear from its previous utility days. I'm going to fit a cubby box and glove box down the line but I would appreciate advice on replacing the torn and worn vinyl around the cab.
I don't have the money for a bespoke finish but would like to repair, modernise and tidy up the plastics and vinyl.
Thanks
Sconie
Post #813751 5th Feb 2020 2:42pm
oneten110
http://www.wrightoffroad.com/products.htm It is not a Defender, it is a One_Ten
Post #813778 5th Feb 2020 6:19pm
sconie
Thanks for that 👍, I'll call them. Hopefully not too pricey. Cheers
Post #813793 5th Feb 2020 7:34pm
donmacn
I was going to suggest the Wright matting earlier, but I don't think they do them for any gearboxes beyond the R380, and I think they're a bit spendy.
That said, I've got a set myself, have had for years and years. I got it at a good price off ebay about 10 or more years ago. The stuff really is bomb proof. I've not long bought a couple of the flat sheets and cut them up to fit in the back, on the strength of how good the front mats are.
If you can get a set for your car, and you can find the cash, you'd never need anything else.
I'd think the easiest other option would be to keep an eye out for a straight replacement for the standard stuff you have. I think it's got a thin foam back from memory, glued onto the seat box. You might be able to pick up some self-adhesive closed cell foam which you could them cover with the outer skin of the standard ones. More likely you'll find carpet 2nd hand, which might do too? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #813817 5th Feb 2020 8:49pm
sconie
Thanks for the reply. I have seen a few online tonight, not sure if they are puma 2012 or not though? If it comes to it I'll strip off the current one, make a template and find a suitable material and look that suits and make my own.
Post #813824 5th Feb 2020 9:03pm
Is this any good to you?
https://www.defender2.net/forum/topic70946.html Darren
Post #813833 5th Feb 2020 9:24pm
sconie
Thanks Darren, it's the corners on my original that have gone too, what's the damage like and what would I repair it with? If its in better shape than mine I'd be happy to make a contribution.
Post #813837 5th Feb 2020 9:38pm
You may find a corner protector might hide some of the wear. (It depends on if the protector is wide enough to cover it?
The Seatbox corners are a common wear point, mine has had the exact same thing happen. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #813839 5th Feb 2020 9:57pm
sconie
Thanks yet again.... You wouldn't have a source for such an item? Might be a big saving. Cheers
Post #813842 5th Feb 2020 10:11pm
PCM
Hi sconie
The bits on offer are mine.
They were from a 2015 puma with 20,000 miles and apart from needing a corner protector £15 are in mint condition.
Only removed them as i removed the interior to replace with carpet.
Thumbs Up
Protectors are £15 a side
Post #813855 6th Feb 2020 12:09am
sconie
Hopefully in better condition than mine then, I'm up in Glasgow so would need a courier type delivery, if you can let me know the postage cost id be happy to contribute a donation then repair.
Sconie
Post #813856 6th Feb 2020 12:16am
Take a look at Mud UK, these are the ones I have. You may find there are others out there that are a bit bigger and might cover more of the area.
Even if they don't it would look better.
Sourcing these mats isn't easy, mine is tatty too and worn even though it hasn't had much actual wear.
Usually on corners.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #813857 6th Feb 2020 12:19am
