![]() | Home > Puma (Tdci) > Defender 90 roof construction |
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
It is continuous, but surely your ligjht fitting is higher than the internal lip of the roof or am i getting the wrong end of the stick here?
| muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122
I'm not sure hence the post.
I think I'll silicone around the alpine lights anyway & see as I can't find any other portal of entry; the gush of water seemed too much for condensation!! Richard Defender 90 SVX |
| Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114
Here you go.
If you need more pics just ask.
Click image to enlarge Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
For what it's worth, my 110 van's roof has been dripping with condensation most of the winter. I wonder if that's what yours has done while unused and it's just collected there.
Mine's used daily so it probably doesn't have a chance to pool. |
Excellent pics thanks. Looking at the level of the gutter, I'm sure you're right.
Some of the leaks appearing from the top of the A post maybe from the gutter channelling water along though. Having been using the vehicle daily this week, there's been nothing at all but then we've not had much rain either. Will W&S & thanks again! Richard Defender 90 SVX |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
It's not unknown for the joint between the sloping and horizontal parts of the roof to leak, for some reason this seems to be very common on double-cabs.
OK, so pressure washed the alpine lights & no leak
Now, the side windows, well that's another story. Water comes in like Niagara Falls Hey ho, a job for another time......... Richard Defender 90 SVX |
| buydefenders Member Since: 03 Feb 2020 Location: Istanbul Posts: 28
We have a garage that specialise in these services. Contact us if you wish |
