![]() | Home > Maintenance & Modifications > Range Rover Sport Seats in my DCPU |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1249 ![]() ![]() ![]() |
Glove box will be where its at. Engine is normally related to engine stuff and high power with boot usually towing and sound system. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Chambo110 Member Since: 25 Jan 2020 Location: Watford Posts: 15 ![]() ![]() ![]() |
So
I found Engine bay fuse box ![]() Click image to enlarge Then these in glovebox ![]() Click image to enlarge ![]() Click image to enlarge Mean anything?? |
So,
After a not very cost effective week in Vegas I can no longer afford for someone to do the work for me. I have eventually found wiring info and am currently making progress on that. Quick question, and probably a stupid one. Could I make the frame as per Bankz pics on 1st page out of aluminium box ? Is there rules and regs ? Only asking as there’s a load of 25mmx25mm x2.5mm laying around at work. I would obviously use steel spreaders at mounting points . safety is most important.. even if it is a defender 😂 Cheers |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
I only use steel as I can weld steel. I cant weld ali yet or I would have.
O right ? Would it be ok for Mr MOT man then ? Thought there may have been rules, and the ally wouldn’t be strong enough ?
Thanks |
Think about it.
How are defender front seats held in? 4 m8 rivnuts into 1.5mm ali sheet. Thats it. Seats dont hold you in a crash, seatbelts do. |
Lol
As soon as I sent my last message I thought of the front seats. Good point . Well made ![]() On the rob at work tonight then Don’t suppose you remember what lengths you used for your rear frame. If ok I will use yours as a rough template. Thanks |
![]() If they're rivnuts on newer vehicles then it confirms my suspicion that the build quality of Defenders took a drastic dive after the 300Tdi. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
![]() Click image to enlarge ![]() Click image to enlarge Can anyone electronically minded help me decipher these please?? im thinking that c33 is the connection blocks in my last pics . But not 100% sure. colours seem to match these diagrams I’ve tested the motors and all work individually but how do I power the seats up please. Thanks in advance |
MikeyC Member Since: 01 Apr 2023 Location: Harpenden Posts: 2 ![]() ![]() ![]() |
I would love to do this mod on my dcpu. I know its a long ahot but have you still got the dims fir the subframe?
It wasnt measured just cut to suit in situ
Fair enough. Thanks anyway.
