Home > Maintenance & Modifications > Range Rover Sport Seats in my DCPU
Page 4 of 4 <1234
Chambo110
United Kingdom 1987 Defender 110 200 Tdi CSW Bonatti Grey
Just been googling that.. seems like there’s 3 fuse boxes .. under bonnet ( engine stuff) glove box. ?? And boot ..
Trying to find glove box stuff first as I’m guess that’s closest.
I hate electrics 😡😡
Post #813633 4th Feb 2020 8:29pm
sako243
Glove box will be where its at. Engine is normally related to engine stuff and high power with boot usually towing and sound system. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #813640 4th Feb 2020 8:40pm
Chambo110
So
I found
Engine bay fuse box
Then these in glovebox
Mean anything??
Post #813643 4th Feb 2020 9:10pm
Chambo110
So,
After a not very cost effective week in Vegas I can no longer afford for someone to do the work for me.
I have eventually found wiring info and am currently making progress on that.
Quick question, and probably a stupid one. Could I make the frame as per Bankz pics on 1st page out of aluminium box ? Is there rules and regs ?
Only asking as there’s a load of 25mmx25mm x2.5mm laying around at work. I would obviously use steel spreaders at mounting points .
safety is most important.. even if it is a defender 😂
Post #815748 18th Feb 2020 9:09am
bankz5152
I only use steel as I can weld steel. I cant weld ali yet or I would have.
Post #815758 18th Feb 2020 10:27am
Chambo110
O right ? Would it be ok for Mr MOT man then ? Thought there may have been rules, and the ally wouldn’t be strong enough ?
Thanks
Post #815774 18th Feb 2020 12:55pm
bankz5152
Think about it.
How are defender front seats held in? 4 m8 rivnuts into 1.5mm ali sheet. Thats it.
Seats dont hold you in a crash, seatbelts do.
Post #815775 18th Feb 2020 1:01pm
Chambo110
Lol
As soon as I sent my last message I thought of the front seats.
Good point . Well made Thumbs Up
On the rob at work tonight then
Don’t suppose you remember what lengths you used for your rear frame. If ok I will use yours as a rough template.
Thanks
Post #815797 18th Feb 2020 4:05pm
sako243
bankz5152 wrote:
Think about it.
Shocked - at least on a 300Tdi they're not. It's M8 bolts into a spreader plate that's riveted in place underneath the aluminium.
If they're rivnuts on newer vehicles then it confirms my suspicion that the build quality of Defenders took a drastic dive after the 300Tdi. Ed
Post #815930 19th Feb 2020 8:00am
Chambo110
Can anyone electronically minded help me decipher these please??
im thinking that c33 is the connection blocks in my last pics . But not 100% sure.
colours seem to match these diagrams
I’ve tested the motors and all work individually but how do I power the seats up please.
Thanks in advance
Post #816403 22nd Feb 2020 1:54pm
MikeyC
England 2006 Defender 90 Td5 PU Tonga Green
Sub frame measurements
I would love to do this mod on my dcpu. I know its a long ahot but have you still got the dims fir the subframe?
Post #987542 1st Apr 2023 12:54pm
bankz5152
It wasnt measured just cut to suit in situ
Post #987543 1st Apr 2023 1:18pm
MikeyC
Fair enough. Thanks anyway.
Post #987546 1st Apr 2023 2:15pm
Page 4 of 4 <1234
