Home > Maintenance & Modifications > Range Rover Sport Seats in my DCPU
Page 3 of 4 <1234>
bankz5152
My seats are welded in the upright position.
Seat mounted seatbelts where removed and I used the original Defender seatbelts without modification.
No airbags in the seats as far as I am aware.
Post #813425 3rd Feb 2020 8:44pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Hm, welding seats solves the "How do I hold a bracket there?" conundrum. In my CSW though it would mean losing the ability to fold seats forward.
My existing second row seats are already moved back to increase leg room and seatbelts mounted through a plate above the rear sliding window by previous owner. I can't imagine there is much strength there at all. Even if I made up a beefy steel bracket to go down to the tub, around the window, I can't see it holding in a crash. Although no crash in a Defender is going to be fun.
Post #813457 3rd Feb 2020 11:30pm
bankz5152
End of the day its the seatbelts thatd holding in the event of a crash not the seat.
As far as I could tell my seats the folding mech for the seat backs where not connected to the seatbelts in anyway
Post #813470 4th Feb 2020 7:16am
sako243
bankz1512 is right, it's the seat belts that hold you not the seat.
The bracket is one of the reasons why I went USW rather than kept the window, I didn't have to worry about keeping visibility. The original LR method is only a little (albeit beefy) bracket in the corner of the C pillar. It's only held in by (from memory) 4 little M6 bolts but it's the design of it that takes the brunt by spreading the load into the corner. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #813486 4th Feb 2020 9:41am
bankz5152
I did replace mine with 10.9M8s and A4 Form g washers and A4 nylocs bit more meaty!
Post #813497 4th Feb 2020 10:56am
Chambo110
United Kingdom 1987 Defender 110 200 Tdi CSW Bonatti Grey
Bankz
Could I trouble pic of your front seats please. I can’t see how I’m gonna get the fronts in and have space for me legs under the steering wheel without altering seat box ??? Or me legs.. legs would probably be easier but walking the dog would then be a problem. Razz
Thanks
Post #813582 4th Feb 2020 5:36pm
Chambo110
Oh my god !! I’ve only just realised my LR sport “front seats” are not same as yours??!!?!?
Note to self .. pay more attention in class
Post #813583 4th Feb 2020 5:39pm
bankz5152
Ive got Corbeau RRS seats in the front Laughing
Post #813585 4th Feb 2020 5:55pm
Chambo110
Yeah ... sh*t
How high are they at the front. From seat box top to top of seat cushion please..
Anyone want some heated, electric and cooled rrs fronts ? Lol
Post #813587 4th Feb 2020 6:05pm
bankz5152
I have seen people fit L322 seats in the front, with a sport steering wheel
Post #813588 4th Feb 2020 6:16pm
sako243
L322 seats with bog standard Defender steering wheel... Whistle OK it's a little tight but perfectly driveable and after 3 years I can honestly say I wouldn't go back!
Don't know if the sport seats are the same as the 04MY L322 ones but I did remove the bracket and motor that does the front of the squab adjustment. Didn't do anything else - just simply removed it, yes the front does flop around a little but you're sat on it most of the time so no flop. Ed
Post #813598 4th Feb 2020 7:10pm
Chambo110
Pics are of connector on passenger seat ..
I’m wondering if the l494 Seat lifts up at the front???
I sat the seat on top of seat box ( pass side) and measured to top of cushion.. then when offered up to drivers side I won’t have space for legs under the wheel.
So if I can figure out how to power up I can see if the front behind the knee bit is currently raised up.
I’m assuming there’s no winding mechanisms in case of power failure ??
Post #813609 4th Feb 2020 7:32pm
sako243
I'd take an educated guess that the two big fat wires are the 12V supply to the control board.
The motors themselves if they've just got two wires will be normal DC motors so you can probably connect 12V directly to them to spin them over.
There's no manual adjustment I think. Ed
Post #813615 4th Feb 2020 7:49pm
Chambo110
That’s kinda what I was guessing.
Might try tomorrow to put power to the red fat one. Black fat to Earth .. I would assume the grey with red trace ( also a fat one) is switch live maybe ??
Post #813625 4th Feb 2020 8:09pm
sako243
Is the cooling built in? Might be a supply for that.
You might get a hint if you can find a diagram of the fuse box in the original vehicle. That would atleast help narrow down what circuits are fed independently. Ed
Post #813626 4th Feb 2020 8:11pm
Page 3 of 4 <1234>
