Home > Maintenance & Modifications > Tyre Inflator this ok?
Stacey007
Hello
Just after a small inflator to keep in boot with other kit?
Will something like this pump up Defender tyres or do I need something more heavy duty?
It will save me using my bike foot pump !!
https://www.amazon.co.uk/Ring-RAC620-Analo...mp;sr=8-72
Thanks
Post #812720 30th Jan 2020 5:18pm
Swine&Small
Does mine OK Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #812721 30th Jan 2020 5:23pm
Litch
I carry one of these Bonaire units in the back of the 90 and another in my motorcaravan, a bit more heavy duty than the one listed but bought from Costco not a huge amount more expensive (come in a natty bag as well!).
The performance far exceeds the cheaper models (meaning you are running it for less time) and also they don't get as hot. They draw a bit more current but I have never blown a fuse yet.
 ONE LIFE, GET IT!
Post #812735 30th Jan 2020 6:39pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
https://www.ebay.co.uk/itm/T-MAX-12V-Air-C...1146879743
The TMax is quite popular with Defender owners. Comes in two sizes
Much more expensive than the ring thought at £70 for the smaller one
Post #812809 31st Jan 2020 9:47am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've had two of the cheap units, first one read pressure correctly which prevented it from inflating above 0.5 bar and second failed to work after a the second time I used it. Maybe it was bad luck, but I'd say for the price it was to be expected.
Post #812814 31st Jan 2020 10:00am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I have the TMax but its a PITA to dismantle the passenger seat to get to the battery every time you want to pop a bit of air in your tyres.
I now use a Clark JumpStart with compressor - just as good and "wireless" too!!
https://www.machinemart.co.uk/p/jump-start-910-cw-12v-compressor/
Post #812817 31st Jan 2020 10:03am
oneten110
kmac wrote:
https://www.ebay.co.uk/itm/T-MAX-12V-Air-Compressor-Small-Portable-HEAVY-DUTY-Tyre-Inflator-Car-Truck-4x4-/331146879743
Had one for over 20 years, handy piece of kit It is not a Defender, it is a One_Ten
Post #812854 31st Jan 2020 2:24pm
miker
I killed a few of the various "cheap" units with land rover, trailer and van tyres.
Tried to justify an ARB, ended up with the big T-Max, and very happy with it! Put an anderson connector on it, and have andersons front and rear in the truck so that I don't have to dismantle the seat!
Post #812855 31st Jan 2020 2:33pm
Stacey007
Thanks all
I've bought an AA one which had auto cut off once it reaches Psi
It's from Amazon so will try it & if no good upgrade 👍👍
Post #812894 31st Jan 2020 6:17pm
JOW240725
I've used a cheapy one for years, work well just very slow. I changed it for an auto cut off so at least you can leave it to it. Works very well. Even has a little light which is useful. James
Instagram @suffolk_rovers
Post #812910 31st Jan 2020 7:16pm
