![]() | Home > Maintenance & Modifications > Tyre Inflator this ok? |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3853 ![]() ![]() |
Hello
Just after a small inflator to keep in boot with other kit? Will something like this pump up Defender tyres or do I need something more heavy duty? It will save me using my bike foot pump !! https://www.amazon.co.uk/Ring-RAC620-Analo...mp;sr=8-72 ![]() Click image to enlarge Thanks |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Does mine OK ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/T-MAX-12V-Air-C...1146879743
![]() Click image to enlarge The TMax is quite popular with Defender owners. Comes in two sizes Much more expensive than the ring thought at £70 for the smaller one |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
I've had two of the cheap units, first one read pressure correctly which prevented it from inflating above 0.5 bar and second failed to work after a the second time I used it. Maybe it was bad luck, but I'd say for the price it was to be expected.
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 630 ![]() ![]() ![]() |
I have the TMax but its a PITA to dismantle the passenger seat to get to the battery every time you want to pop a bit of air in your tyres.
I now use a Clark JumpStart with compressor - just as good and "wireless" too!! https://www.machinemart.co.uk/p/jump-start-910-cw-12v-compressor/ ![]() |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Had one for over 20 years, handy piece of kit It is not a Defender, it is a One_Ten |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
I killed a few of the various "cheap" units with land rover, trailer and van tyres.
Tried to justify an ARB, ended up with the big T-Max, and very happy with it! Put an anderson connector on it, and have andersons front and rear in the truck so that I don't have to dismantle the seat! |
Thanks all
I've bought an AA one which had auto cut off once it reaches Psi It's from Amazon so will try it & if no good upgrade 👍👍 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
I've used a cheapy one for years, work well just very slow. I changed it for an auto cut off so at least you can leave it to it. Works very well. Even has a little light which is useful. James
