![]() | Home > Technical > Alarm sounding when starting, after periods of inactivty |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
When you turn over the engine the battery voltage drops so the alarm sounds as it thinks the battery has been disconnected.
Main battery must be losing charge - keep it topped or replace, |
Galyman Member Since: 20 Jan 2016 Location: Scottish Borders Posts: 92 ![]() ![]() ![]() |
Cheers kmac.
Taking it out on an extended run tomorrow so will give it a decent charge. Will then turn over daily and see if the it is losing charge relatively quickly or just when left for long periods if time. |
rockhound42 Member Since: 24 Jun 2015 Location: where Surrey meets Sussex Posts: 38 ![]() ![]() ![]() |
I had a similar issue and after lots of head scratching found a bad bulb causing a short and draining the battery quicker than normal, bulb fixed and no more problems still running fine on the same odyssey pc1500 5 years later
Any tips for getting to the bottom of what was causing the battery drain?
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
how old is the battery ? you could have a load test on it used to be free at Halfords just don't buy a battery there if you need one
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5961 ![]() ![]() |
For your info
If you talk to Oddesy they will tell you to, at least once a year take the out of the system and give them a full bench charge with a quality charger such as a ctek charger. It certainly helped mine when I did what was recommended |
Andydef90 - Both batteries are about 4 years old.
landyandy - will look at getting both of them charged up. |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
I have two Defender 2.2. One used every day, the other once a week at best. Both turnover quickly and start immediately. I get a alarm, often on both, sounds like a bird whistling ( no birds were harmed in the writing of this thread) is this the alarm to which you refer as I’ve often wondered what it is.
The hard way - remove all fuses and start putting them back one by one whilst measuring if there is any draw on the batter |
Or one of the current draw tools from this thread:
https://www.defender2.net/forum/post810324...ley#810324 |
Hmmm, using the tool seems to be a less laborious option.
Wow, that was an extended run.
Kind of lost track of time. Battery or batteries do need a charge. Any suggestions for a charger and whether it can be done in situ or better to remove them and charge indepently?
Have a search for CTEK on here will find you a range of options; including some of the best kit for charging insitu.
