Home > Technical > Alarm sounding when starting, after periods of inactivty
Galyman
Scotland 2013 Defender 110 Puma 2.2 HT Aintree Green
Hello
Looking for some advice. I have a 2011 Tdci 90 with a dual odyssey battery system and a relay switch. The Defender does not get as much use as it should at the moment so can sit idle, without being started for a week or more at a time. When I do come to start it, and turn the ignition, an alarm sounds until it turns over. It is not the noisy alarm, it is a more high pitched sound which is not too loud. I would hope it is not battery related as I thought the odyssey PC1500s were amongst the best, and are only a few years old.
Post #810087 13th Jan 2020 7:37pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
When you turn over the engine the battery voltage drops so the alarm sounds as it thinks the battery has been disconnected.
Main battery must be losing charge - keep it topped or replace,
Post #810118 13th Jan 2020 9:40pm
Galyman
Cheers kmac.
Taking it out on an extended run tomorrow so will give it a decent charge. Will then turn over daily and see if the it is losing charge relatively quickly or just when left for long periods if time.
Post #810126 13th Jan 2020 10:04pm
rockhound42
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I had a similar issue and after lots of head scratching found a bad bulb causing a short and draining the battery quicker than normal, bulb fixed and no more problems still running fine on the same odyssey pc1500 5 years later
Post #811147 20th Jan 2020 12:53pm
Galyman
Any tips for getting to the bottom of what was causing the battery drain?
Post #811370 21st Jan 2020 9:51pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
how old is the battery ? you could have a load test on it used to be free at Halfords just don't buy a battery there if you need one
Post #811841 25th Jan 2020 9:02am
landy andy
For your info
If you talk to Oddesy they will tell you to, at least once a year take the out of the system and give them a full bench charge with a quality charger such as a ctek charger.
It certainly helped mine when I did what was recommended
Post #811844 25th Jan 2020 9:32am
Galyman
Andydef90 - Both batteries are about 4 years old.
landyandy - will look at getting both of them charged up.
Post #811967 25th Jan 2020 9:53pm
nidge n
I have two Defender 2.2. One used every day, the other once a week at best. Both turnover quickly and start immediately. I get a alarm, often on both, sounds like a bird whistling ( no birds were harmed in the writing of this thread) is this the alarm to which you refer as I’ve often wondered what it is.
Post #812092 26th Jan 2020 10:02pm
kmac
The hard way - remove all fuses and start putting them back one by one whilst measuring if there is any draw on the batter
Post #812216 27th Jan 2020 8:51pm
Or one of the current draw tools from this thread:
https://www.defender2.net/forum/post810324...ley#810324
Post #812339 28th Jan 2020 7:07pm
Galyman
Hmmm, using the tool seems to be a less laborious option.
Post #816051 19th Feb 2020 9:02pm
Wow, that was an extended run.
Post #816069 19th Feb 2020 10:52pm
Galyman
Kind of lost track of time. Battery or batteries do need a charge. Any suggestions for a charger and whether it can be done in situ or better to remove them and charge indepently?
Post #816072 19th Feb 2020 10:56pm
Have a search for CTEK on here will find you a range of options; including some of the best kit for charging insitu.
Post #816096 20th Feb 2020 7:51am
